Dana 60
Old Feb 9, 2009 | 08:47 PM
cyberbrain's Avatar
Default Dana 60
Ok, I am really considering putting D60's in my JK. But I have a few questions, that I can't find answers for with search.
1. Are the axles full width, or are they shorter for the JK?
2. If they are shorter, would I be able to cut the tubes and reweld the ends?
Old Feb 9, 2009 | 08:57 PM
km2jk's Avatar
I believe that they add a bit to the width, but they are definately not full width. You could likely order a custom width, but the price might be ever scarier than what it usaully is.
Old Feb 9, 2009 | 08:58 PM
zacsquatch's Avatar
They are almost always wider... seeing as they are almost always from 3/4-1 ton pickups Thus they are FULL WIDTH
And if you want stock width, you can cut them down and order custom shafts
Old Feb 9, 2009 | 09:08 PM
km2jk's Avatar
I believe that he is talking about ordering a custom set for the JK. They are built to bolt in and are not from a truck. It is possible to use junkyard axles, but there are a lot of electrical problem going that route. If that is the case, they are not going to be as wide a the front of a dually
Old Feb 9, 2009 | 09:49 PM
David @ Currie Ent.'s Avatar
Former Vendor
Full width........ How wide is full width?
The term full width is used a lot now days, but what does it really mean!!!
When building a CJ, full width meant 63"-67" wide, the width of a stock full size truck axle. The stock CJ track is 56" wide if you have a "wide track" CJ, so going to a 63"-67" axle is a huge difference.
Now lets fast forward a few years, 2007..... the JK was born. Stock width for a JK is 65.5" wide, so............ does that make the JK a "full width" vehicle? If not how wide would "full width" be considered on a JK?
Currie will make axle assemblies just about any lenght you want.
We stock Rock Jock 60 rear end assemblies that are 66" wide and 1 Ton front end assemblies that are 68 3/4" wide.
Mfg: JK-RJIIIF
Our Price: $4,999.95
Description: The RockJock® III high pinion frontend assembly for the 2007 and up Jeep JK includes the complete housing featuring the 65-45-12 ductile iron housing center (highest ground clearance 60 on the market), AR400 heat treated bottom skid plate allowing the axle to slide over rocks easily, 3" d.o.m. steel tubes, 1 ton inner knuckles, 5/16" thick heavy steel diff cover, yoke (1310/1330/1350 optional), and all new heavy duty Currie Jeep JK suspension brackets mounted with Johnny Joint® equipped upper control arm mounts for maximum articulation. Axles shafts are the Currie performance 4340 35 spline inner and outer with Spicer 1480 u-joints. Outer assemblies include 1 ton outer knuckles featuring Currie upper steering arm and ball joints installed, Currie exclusive 1 ton unit bearings with 5 on 5 1/2" wheel bolt pattern and JK tone rings allowing for ABS and ESP retention, 13" vented rotors (over 1" greater diameter than stock for increased braking), zinc plated caliper brackets that retain the stock JK front calipers, Currie drive flanges or Warn premium manual locking hubs, and our heavy duty 1 1/4" o.d. 4130 chrome moly tie rod with tie rod ends. Additional parts needed to complete this unit are a high pinion Dana 60 ring and pinion gear set, Dana 60 35 spline carrier of your choice, and a bearing & set up kit. Assembly labor of this unit is included in the price!
Mfg: JK-RJIIIR
Our Price: $1,899.95
Description: The RockJock® III high pinion rearend assembly for the 2007 and up Jeep JK includes the complete housing with the 65-45-12 ductile iron housing center, AR400 heat treated bottom skid plate allowing the axle to slide over rocks easily, 3" d.o.m. steel tubes, 5/16" thick heavy steel diff cover, yoke (1310/1330/1350 optional), and custom housing ends that accept set 80 axle bearings (over 50% greater capacity than stock) and allow for all factory disc brake hardware and ABS and ESP sensors to bolt back on. All new heavy duty Currie Jeep JK suspension brackets are mounted and feature adjustable control arm mounting holes, adjustable trac bar mounting holes, and adjustable shock mounting holes. Also included are the Currie performance forged alloy 35 spline axle shafts that are dual drilled with the stock JK 5 on 5" wheel bolt pattern as well as the 5 on 5 1/2" wheel bolt pattern. Axles feature wheel studs, ABS tone rings, and axle bearings pressed on, as well as the bearing retainer plates. The only parts needed to complete this unit is a high pinion Dana 60 ring and pinion gear set, Dana 60 35 spline carrier of your choice, a bearing & set up kit, and your JK's stock rotors, calipers, and caliper mounting brackets transferred over. Assembly labor of this unit is included in the price!
Old Feb 10, 2009 | 09:30 AM
Rubicon Rando's Avatar
^ damn... those axles is sexy
Old Feb 10, 2009 | 09:35 AM
Paul le corre's Avatar
Thanks for those info. You're really going hardcore when you put those on your JK!!
Old Feb 14, 2009 | 08:12 AM
08SaharaM6's Avatar
Maybe a dumb question, what makes the fronts so much more than the rears?
I understand there are extra parts there, but $3000 worth?
Old Feb 14, 2009 | 11:26 AM
Worthless's Avatar
Inner and outer Knuckles, ball joints, completely different shafts 2 more at that, spindles, brakes, locking hubs, u-joints, bearings, steering arms, studs......yeah its 3k worth. Its not that these things are designed in regular autoCAD, Im sure they are using a $10k+ program similar of Solidworks that stresses these parts to find weak links. When you get in the engineering aspect of things, there's a little bit of coin in there for R&D also. These are a whole different animal. Rears don't take nearly the same amount of design other than the housing itself.
