AEM BRACKET vs opening the fuse box
Old Apr 29, 2007 | 11:34 AM
captsam54's Avatar
Default AEM BRACKET vs opening the fuse box
After the install of my AEM, the bracket/shroud is in the way of opening the fuse box.. Will only come up half way.. and the fuse placement diagram is on the underside of the lid..!!
Does anybody have a printout, or something I can print showing the fuses etc. where I can actually read/see them from a normal position? IE: looking down at them rather than craning my neck sideways to look at the braille under the fuse cover?? The manual stinks for that.. Any help would be appreciated..
OK OK.. maybe my eyesight is a little old/bad..
Old Apr 29, 2007 | 01:05 PM
zoomzoomjr's Avatar
I tried to put something up on my website that can be printed.
http://jokesbyef.freewebspace.com/fuses.htm
Old Apr 29, 2007 | 01:54 PM
captsam54's Avatar
Hey, thanks, that is better than the manual..I will print it out and put it in my glove box..:<)
BUT, I really need "placement " of the fuses etc. like whats on the "inside" of the lid..
Old May 3, 2007 | 06:03 AM
captsam54's Avatar
Originally Posted by kcirrick
I have the same issue. After unlatching the cover on the fuse box just give it a tug straight up and it will pop right off. When your done just snap it back in and relatch it. Having poor near vision I was doing this before installing the AEM so I could take the cover out in the best light making the small print easier to read.
Oh, thanks.. I was trying to do that and was tigging on it.. but didn't want to break it..!! I will try again.. Thanks again..
