View Poll Results: Do you prefer hawse or roller winch fairleads? Why?
Hawse
15
57.69%
Roller
11
42.31%
Voters: 26. You may not vote on this poll
Fairleads
Old Apr 30, 2007 | 11:37 AM
Andrews's Avatar
Default Fairleads
Hawse or roller fairlead? Which do you prefer and why?
Old Apr 30, 2007 | 11:52 AM
drojk's Avatar
I use a Hawse primariliy because I run synthetic line.
Old Apr 30, 2007 | 11:57 AM
yellowjeeper85's Avatar
I had a hawse on my TJ with steel cable... mostly because it came with the winch i baught and my TJ was pretty capable and didn't get stuck too often. When i was the one pulling others out i usually resorted to a tow strap when possible, and when not, i'd orient the jeep in a way so that the cable basically was sticking straight out from the jeep. On my JK, i don't have a winch yet, but when the day comes, i'd really like to run an aluminum hawse with a synthetic line. But if i do run steel winch cable, i'll likely run the roller fairlead as it seems it would be a little easier on the steel cable then a hawse.
Old Apr 30, 2007 | 12:52 PM
its pretty simple really
hawse for rope
roller for cable
Old Apr 30, 2007 | 01:02 PM
rupedog's Avatar
Hawse because it gives me the option to use ether steel or rope.
Old Apr 30, 2007 | 01:45 PM
greggradwohl's Avatar
You cant use rollers with rope?
Old Apr 30, 2007 | 03:25 PM
IGOFSHN's Avatar
Not true. As long as your rollers are new or not damaged, a roller fairlead is just fine with syn line.
Old Apr 30, 2007 | 03:26 PM
IGOFSHN's Avatar
Originally Posted by PhilD
Syn lines can get pinched with roller fairleads and easily ruined.
Everyone I wheel with in Johnson valley runs syn line and roller fairleads. We've never seen or had a problem with the rollers.
Old Apr 30, 2007 | 03:40 PM
TEV's Avatar
TEV
I don't use cable. I really don't think there are any fairleads that are ok for both rope and cable. I choose hawse but just because of looks. These are my favorites.
x-line
Rokmen
The best for performance and actually taking care of your rope tho is the roller fairlead with the derlin rollers
Derlin rollers
Old May 2, 2007 | 02:18 AM
degenerate's Avatar
