How to adjust front castor without a pinion?
Old Feb 27, 2009 | 09:46 AM
ranwitscissorz's Avatar
Default How to adjust front castor without a pinion?
I was reading the alignment guide and it says to change your castor you would want to push up on the pinion. I'm going to be installing front lower control arms tonight, but I have a 4x2 and do not have a front pinion (please no "buy a 4x4" comments please), any suggestions? Thanks!
Old Feb 27, 2009 | 09:50 AM
wayoflife's Avatar
JK-Forum Founder
if you have front adjustable lowers, simply make them longer. 23" eye to eye is a pretty good starting point and it should give you about +6° of caster.
