Got rubi D44 axles...
Old Mar 5, 2009 | 03:58 PM
PONCH's Avatar
Default Got rubi D44 axles...
Doing a axle swap to rubi D44s. Now what? I was thinking of ORE inner C gussets. They already have diff covers. Should I go ahead and get new shafts why I have them out? Skids maybe too?
Old Mar 5, 2009 | 04:08 PM
BlackNorthernJK's Avatar
lucky sob...
Thats awesome
Good luck on the install. Not sure what else you'll want, gussets and tube inserts might be a great idea while it's out...but if it were me...and it isn't...but if it were, I'd just run the axel shafts that it came with until they were trashed then upgrade, but thats based on a cost concern.
Northridge4x4's Avatar
Sponsoring Vendor
It really all depends on the budget.
Chromoly shafts in my opinion are a must for serious offroading.
ORE gussetts and Skids
And wheel it!
David
Old Mar 5, 2009 | 04:14 PM
PONCH's Avatar
Just talked to a buddy of mine. He told me not to buy any gussets this weekend. No point in buying them when he has a plasma cutter, welder etc etc. He wants to check out the axles and see if he can make some custom stuff.. You should see the scatter shield he made for his Dodge Ram when he does tractor pulls....looks sweet but tractor pulls...hahahaha. To each their own.
There are some perks to being Active duty...lol.
Old Mar 5, 2009 | 05:24 PM
PONCH's Avatar
He also sent me the drive shafts and some other misc parts. Will I need to use the Rubi shafts over the stock x? Is it the same thing?
Old Mar 6, 2009 | 04:17 AM
PONCH's Avatar
Anyone know?
Old Mar 6, 2009 | 06:31 AM
dyolfknip's Avatar
Originally Posted by PONCH
Anyone know?
As far as I know, stock shafts are the same on all models, but it always nice to have spares
Old Mar 6, 2009 | 06:44 AM
jkkat's Avatar
<--busted 2 right stub shafts with stock tires with RubyDoo then changed to Cromolly with NO problems thus far.
Old Mar 6, 2009 | 07:30 AM
VictorS's Avatar
Before you bolt in the axle, you might think about some axles sleeves to strengthen the tubes, some control arm bracket skids and beef up the track bar mount.
Old Mar 6, 2009 | 07:50 AM
PONCH's Avatar
The shafts are a little out of my price range right now and I have no idea what it would cost for the tubes. I've seen the skids and that seems pretty easy to make. I have not looked into the track bar mount.
