35's, Gears, MPG, Transmision
Old Mar 12, 2009 | 04:25 AM
jdhanson's Avatar
Default 35's, Gears, MPG, Transmision
I am wanting to re gear my 4 dr 3.73 auto to allow me to run 35" tires with a 4" lift. What I am wondering since it is a daily driver is...
1 What type of mpg are we looking at with 4.88(or something close to that) and 35" tires?
2 What gears do you recomend?
3 Can you still use overdrive?
Old Mar 12, 2009 | 06:22 AM
wayoflife's Avatar
JK-Forum Founder
4.88's will give you stock like performance but you have to know that your mpg's will never be the same especially with considerably bigger tires.
if mpg is important to you, 4.88's will keep you the most stock. with an auto, i personally would recommend 5.13's as they will give you a boost in power. nothing crazy and nothing that will drain your tank per se but definitely more performance and a little less mpg than 4.88's.
3 Can you still use overdrive?[/QUOTE]
with 5.13's definitely. with 4.88's, most of the time.
Old Mar 12, 2009 | 06:33 AM
greenamphibious's Avatar
5.13s or bust but like he said your MPG will go down anyway
Old Mar 12, 2009 | 04:02 PM
STUPIDFACE's Avatar
the difference in 4:88 and 5:13's is about 100 rpm at about 65 mph. notice i used the word "about" twice in the previous sentence. thats because im not sure exactly what the numbers are, but thats close.......i think.
corey d
Old Mar 12, 2009 | 04:05 PM
bigbluejk's Avatar
I have 5.13s and 35s. the little boost in power is well worth the extra gas gone. now the mpg.... hah. you don't wanna know.
Old Mar 12, 2009 | 05:48 PM
jdhanson's Avatar
Can anyone give me highway MPG #'s?
Old Mar 12, 2009 | 06:12 PM
bigbluejk's Avatar
Lightbulb
are you sitting down?
Old Mar 12, 2009 | 08:56 PM
SB08JK's Avatar
Sorry...it's probably the Jack Daniels, but that cracked me up.
Old Mar 13, 2009 | 04:39 AM
G DIESEL's Avatar
lmao...and what is the answer? I'm going to do the same setup... I'm guessing 15-16 highway?
my 92 Cherokee 4.0L auto with 33's and 4" lift gets 9.5
Old Mar 13, 2009 | 05:21 AM
jkkat's Avatar
<-- can still get 18 hiway MPG with the setup below
