EVO Rockstars question
Old Mar 15, 2009 | 11:15 AM
jeepsanddrums's Avatar
Default EVO Rockstars question
Has anyone installed the EVO Rockstars with the Rubicon Express track bar relocation bracket? I am thinking I will have to cut the RE bracket, install the Rockstar, then weld the track bar bracket to the Rockstar??
I would rather avoid welding if possible.
Any thoughts?
Thanks!
Old Mar 15, 2009 | 12:47 PM
jayrav's Avatar
I have a set of the Evo Rockstars with Tera relo bracket. Didn't have to cut the bracket. Could you elaborate regarding your relo bracket? Maybe post some pics?
Old Mar 15, 2009 | 01:26 PM
The RE track bar relocation bracket uses the same two holes that the Rockstar brackets use.. I don't think this is an issue with the Full Traction or Teraflex bracket, but it is with the RE.
Old Mar 15, 2009 | 01:32 PM
Robar's Avatar
You may cut a slot in the RE bracket so it slides over Rock stars and still use both bolt holes, but it would still be a good idea to weld the RE bracket to the Rock star on the out side of the shock mount.
Old Mar 15, 2009 | 05:36 PM
Maybe I should just order up a Teraflex or Full Traction track bar relocation bracket since I have heard they will not interfere?
Old Mar 15, 2009 | 05:41 PM
Robar's Avatar
You could do that, but the TeraFlex and the Rock stars are a very tight fit. It took some tweeking and a longer control arm bolt before I could get it all back together. But it is tight and fits good.
Old Mar 15, 2009 | 05:58 PM
jayrav's Avatar
X2! LIKE MINE
Old Mar 18, 2009 | 04:15 PM
Thought I would update and let everyone know that the Rockstars do fit with the RE track bar relocation bracket. I grinded a bit off of the track bar relocation bracket and it went in no problem.
I still need to see if the stock sway bar links will be ok. They sit at a bit of an angle and look kind of funny.
I still need to cycle the suspension.
Old Mar 18, 2009 | 04:55 PM
wiredawg_mg's Avatar
Glad this thread came up. In the last 2 weeks I have dented the drivers side shock mount and the passenger mount and shock.
Need to fix this soon.
Old Mar 19, 2009 | 03:18 AM
ytee's Avatar
I have the Rockstars and the Teraflex track bar mount. All I did was cut the Teraflex mount where it went to the lower control arm, shortened it a little and then welded the mount to the rockstar. I talked with Mel and he said this was a good way to make it work.
