Popping Noise
Old Mar 15, 2009 | 04:22 PM
Wizeguy's Avatar
Default Popping Noise
Hey guys - I have a 4" rough country with 35" tires. When I apply brakes I have a slight pop in the right rear - then when I gas from a red light I have the same pop. Only breaking and then gassing. I don't know if it is my springs or a control arm or what. Any suggestions?
Old Mar 15, 2009 | 04:45 PM
KMacJKPA's Avatar
Did you replace the control arms? If so, check to see if they torqued correctly.
Old Mar 15, 2009 | 06:20 PM
Wizeguy's Avatar
didn't replace them but did loosen them and don't know if they were torked correctly
Old Mar 15, 2009 | 06:27 PM
backroadman81's Avatar
I would go over all your suspension parts and make sure everything is tight. Also look and see if there is rub marks on your arms. check your track bar if it is adjustable I did't tighten the jam nut and it tore the threads out
Old Mar 16, 2009 | 04:45 AM
Calypso's Avatar
After checking to make sure all is torqued properly, check your rt rear coil spring and see if your track bar may be rubbing it. It is a very tight clearence on many lifts.
Old Mar 16, 2009 | 05:41 AM
jkkat's Avatar
x3 on checking torque on the suspension parts and track bars too
Old Mar 16, 2009 | 05:51 AM
07Rubi2dr's Avatar
I had this issue with my 2.5" lift. Turned out my shocks loosened up and that's what was making the sound.
