Rims & Tries
Old Nov 17, 2006 | 02:41 PM
JKonorder's Avatar
Default Rims & Tries
Will 18" x 9.5 Rims and 35 x 12.5 Tires fit. If not what back spacing would I need to look for?
Old Nov 17, 2006 | 02:54 PM
FzyPchz's Avatar
Refer to the tire manufacturer's spec sheet for minimum and maximum rim/wheel size.
Old Nov 17, 2006 | 02:58 PM
JKonorder's Avatar
OK I will ask a stupid question. Where do I find it???
Old Nov 17, 2006 | 03:28 PM
FzyPchz's Avatar
Not a stupid question at all! Which tire are you interested in? Companies (ie, Toyo, Interco, BFG to name a few) have their tire specs available online. Here's an example of Toyo's (see the Rim Width Range column): http://www.toyo.com/docs/tires/produ...;&category=lgt
You can also check Tirerack.com's website (but I prefer going directly to the manufacturers site).
Hope that helps!
Old Nov 17, 2006 | 03:38 PM
JKonorder's Avatar
This is what i`m thinking of going with, but with an 18" wheel. I`m not that fond of spacers, I`d rather find someone that would make the rim the way I need it.
http://www.procomptires.com/xtrememudterrain.html
http://www.americanracing.com/appgui...le=329&id=1345
Any advice would help.
Thanks.
I already ordered 3" Full Traction Ultra Lift.
Old Nov 17, 2006 | 07:20 PM
FzyPchz's Avatar
From what I've read in various forums, procomp tires aren't all that great (expensive and wears fast, etc.). Toyo's MTs seemed to get better reviews. I personally will be getting BFG ATs (I do mostly highway driving) and have had good experience w/ it.
