Sagging in the Stern
Old Mar 19, 2009 | 08:17 AM
sully151's Avatar
Default Sagging in the Stern
I just installed my LoD bumper and tire carrier and lost about .75 of an inch out of my TF 3" lift. I want it back.
I thought I could throw a 1" spacer in there, but because of the spring retainer spacer (1" cone shaped spacer) I can't.
I talked to WOL last night and he said swap it out with a 1. 75" spacer, but TF doesn't make one. They have a 2.5" spacer. would that work? I would end up .75" taller than before, but I guess when I add jerry cans, trail rack, and camping gear I will lose it again.
Thoughts or suggestions?
Old Mar 19, 2009 | 08:19 AM
TeraFlex's Avatar
Sponsoring Manufacturer
We have 1/2"-1"-2.5". You could get a 2.5" and then cut/grind/machine it down to a custom height.
Old Mar 19, 2009 | 08:29 AM
wayoflife's Avatar
JK-Forum Founder
hey sully, looking at your jeep, i would definitely go with the 2.5" spacers. at worst, i think it will give you a factory rake but the minute you load up your jeep with people and/or gear, you'll be glad that you have a little rake back. of course, if it's more than you'd prefer, it would be very easy to level out your front end.
Old Mar 19, 2009 | 08:30 AM
dadgummit's Avatar
Daystar makes .75" spacers for the rear.
Old Mar 19, 2009 | 08:31 AM
wayoflife's Avatar
JK-Forum Founder
unfortunately, you cannot stack spacers with a TF rear spacer as it has a retainer peg.
Old Mar 19, 2009 | 08:47 AM
RedneckJeep's Avatar
Just let some water in the bow and all will be well.
dadgummit's Avatar
ok I understand.
I am having the same trouble and I don't even have the rear bumper yet. I put an extra 1/2" spacer in back and a 1" in front to compensate for the arb bumper and I ended up 1/4" higher in front. I added the winch last weekend and I am still about 1/4" higher in front. Either the rears settled in or the 114 pound winch did not effect the fronts at all.
Old Mar 19, 2009 | 08:51 AM
wayoflife's Avatar
JK-Forum Founder
ok I understand.
sounds like all you really need to do is replace your existing rear spacer with something a little taller
Old Mar 19, 2009 | 08:57 AM
dadgummit's Avatar
I was planning on replacing the rear TF 1/2" with the tf 1" and, once I get the rear bumper later, cutting out the factory front spring retainer. I plan to cut it out since it took too many hours getting those springs in there.
Old Mar 19, 2009 | 05:32 PM
STUPIDFACE's Avatar
mine was also dragging ass after i installed the lod rear bumper / carrier. i threw on a 1" body lift and got it back. i dont know how much i lost cuz i was like a kid at christmas when i got the bumper and forgot to take measurements. didnt look like 3/4 of an inch though.
corey d
