Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
For installers inexperienced with the JK Rubi lockers, it is not uncommon for them to damage the locker sensor. Apparently, there is some sort of trick to reinstall the carrier without damaging the sensor.
If you do a search, you will find some threads on this.
Yeah, it's called "paying attention to detail"! Seriously lacking in a lot of shops.
Yes, the installers messed up my rear sensor and had to replace it. The lockers still locked
by was not noted by the dash light. Common problem with inexperienced installers.
The first thing my shop did was put it 4 wheel drive to amke sure that it worked. I just carried it back for a 500 mile checkup. No problems and had Rockcrusher difs installed.
