re-gearing
Do you have a 2wd? if not you have to do front and rear. You will F#$% stuff up bad if you just change one axle. Like said above transfer case is different. As far as I know there are no kits out there to change ratio of JK transfer cases yet. There may be some 4:1 kits later on like for the TJ but that will only affect 4 lo.
qft. I wouldn't let him near my rig if he doesn't know you must do both... then again I am real picky. If I don't do something myself, it is getting done by a shop with a good reputation. Nothing against your friend, but if he screws up, I doubt he is going to repair/replace anything.
why do you need to mark it and how? I am wondering. Straightening the steering wheel after lift is as easy as changing the oil, maybe even easier.http://project-jk.com/jeep-jk-write-...-end-alignment
