3.5" skyjacker lift??
Old Mar 26, 2009 | 10:56 AM
jeffnesom's Avatar
Default 3.5" skyjacker lift??
I just purchased a 3.5" skyjacker lift for my 2008 2 door jk and the 3/4" front spacers to make it sit level. I use my jeep everyday mainly to drive back and forth to work but also at the deer lease which is about a seven hour drive from home. My question is how important is it for me to replace my front and rear driveshafts if i don't do any serious off roading? And , am i going to have any problems with the drive shaft angles with that lift.
Old Mar 26, 2009 | 11:01 AM
wayoflife's Avatar
JK-Forum Founder
the rear will go out on you sooner than later and you can address it then. if you have a 6-speed, you will not need a front one. if you have an auto and if you do not do any wheeling, you should be fine with your front shaft as well. however, if you do have an auto and go wheeling, the spline shaft boot on your front shaft will tear off on the tranny pan and will need to eventually get replaced.
Old Mar 26, 2009 | 11:04 AM
jeffnesom's Avatar
do you have any suggestions for where to get the driveshafts ? or what kind ?
Old Mar 26, 2009 | 11:07 AM
wayoflife's Avatar
JK-Forum Founder
j.e. reel, teraflex and coast all make good 1310 replacement drive shafts. all of our sponsoring vendors will have these. you will also need to get a set of adjustable rear upper control arms as they will be needed to set your pinion angle.
Old Mar 26, 2009 | 11:14 AM
jeffnesom's Avatar
Post
thanks for the help. so much for buying a complete kit with "everything i need" so skyjacker told me. I wish I would have heard of this site before I bought it. LOL.
