Rear FT Trac-bar rubbing on spring
A few months ago I put on a 3" FT Ultimate lift on my 4dr Rubicon. For some reason the rear trac-bar rubs on the right rear spring. Everything else is fine with the lift and all the measurements seem correct. It's almost as if the rear spring diameter that was supplied with the lift is too large or the bend in the trac bar is incorrect.
Has anyone else encounter this problem?
In the pic you can see where the bar has rubbed off the coating on the spring...
Thanks,
andrew
Thanks,
andrew
