3'' lift kit sway bar links problem!!!!
Old Mar 29, 2009 | 07:38 PM
tento0929's Avatar
Default 3'' lift kit sway bar links problem!!!!
hi
ive instaled today the full traction 3'' premium lift kit and the sway bar links have no clerence whith the wheel on the left side.... look at the pictures.
and im olso ggeting the feel that the front is higher look at the picture too...
thanks averybody hope someone can help because i have no car jejejej
Stefano T.
ID:	21460   Click image for larger version
ID:	21461   Click image for larger version
Old Mar 29, 2009 | 07:46 PM
wayoflife's Avatar
JK-Forum Founder
you are running factory wheels and they have way too much back spacing. you will need to install the links on the inside of the sway bar, get new wheels with less backspacing or install wheel spacers. regarding your front end, the kit is designed to level out your factory rake.
Old Mar 29, 2009 | 07:53 PM
blazer4949's Avatar
Yes, I had the same problem with my Teraflex Full Flex 3" lift. Had to add the TF rear trackbar
brace which included the upper bracket that is a couple of inches up. It was explained to me
that the trackbar more level with the axle pulling on the axle would prevent the swaybar links from hitting the tire under
flex conditions. And....I need to go back and have the adjustable trackbar adjusted so
my rear axle is more centered, now about an inch off.
Just read the above post, will have to move the swaybars to
the inside!!
Old Mar 30, 2009 | 09:56 AM
JKGoose's Avatar
Yup. That's all normal. That's exactly how mine was. Folow WOL's advice and you'll be good to go.
I assume you got the lift so that you can put bigger tires on it. If you stay with the stock rims you'll need wheel spacers so the tires won't rub. The spacers will also give you the clearance you need for the sway bar links. Or, if you get new wheels, they will have more backspace which will give you the clearance too.
See the Wheels and Tires FAQ for more backspacing info:
https://www.jk-forum.com/forums/show...74&postcount=3
Old Mar 30, 2009 | 11:35 AM
tento0929's Avatar
ok thanks im going for the rugged ridge 1''1/4 spacer thanks
regardigs too the thing i feel that the car is higher in the front and you say thats noirmal the question is what would happen if i add some wheight in the back? woul it look stranger???
Old Mar 30, 2009 | 01:10 PM
vogeljk's Avatar
Default The Rake
Put a winch and a steel bumper on it.
Old Mar 30, 2009 | 03:35 PM
StevieRay's Avatar
I have the same lift and installing the links on the inside corrected it for me.
Old Mar 30, 2009 | 04:29 PM
tento0929's Avatar
I have a mopar steel front and back bump and a warn 9.5ti winch.....
Old Mar 30, 2009 | 04:47 PM
blazer4949's Avatar
Just came back from ORE, going with 1+" spacers on all 4 wheels to correct swaybar links from
hitting rear tires on full flex.
