Installing 4" lift What control arms?
Old Apr 8, 2009 | 03:00 PM
lunkhead22's Avatar
Default Installing 4" lift What control arms?
Some fellow members from the Jk forum are helping me install a lift. Thanks Guys!!! But my question is what minimal control arms can I get away with for a while ? Uppers, Lowers Front or rear. I have a 6 speed Sahara. Looking to spend less then $500.
Old Apr 8, 2009 | 03:06 PM
Calypso's Avatar
Do you have a 4 door? You can "get by" without any but it probably won't drive very good. Go with front lowers and rear uppers.
Robar's Avatar
The minimum recommended control arms are front lowers, to adjust caster, and rear uppers, to adjust pinion angle.
Old Apr 8, 2009 | 03:50 PM
lunkhead22's Avatar
Are any of you guys running that setup?
Old Apr 8, 2009 | 04:05 PM
hammerhead's Avatar
I'm running the RC 4" with front adjustable lowers set at 23" and it drives great.
Robar's Avatar
There are some members running that set up. I have all eight. The nice thing is that you can start with the front lowers and rear uppers then add the rest later if you feel you need them.
Old Apr 8, 2009 | 04:22 PM
lunkhead22's Avatar
Thanks guys! I won't be doing any rock climbing, just mud. Can I get away with none or even just front lower? sorry I'm just wondering safety plus I don't have the extra cash at the moment.
Old Apr 8, 2009 | 04:29 PM
Robar's Avatar
I think with a 4" lift you will at least wont front lowers to adjust caster and help keep the steering from being flighty.
Old Apr 8, 2009 | 04:32 PM
lunkhead22's Avatar
Do you think I can get away with front lowers only? Have you have seen that done? I can afford the front lowers and get the rest in a couple months. (I should wait for everything before I get the lift installed but its been two months)
Old Apr 8, 2009 | 04:33 PM
lunkhead22's Avatar
I forgot to mention I also have dual steering stabilizers.
