Front sway bar quick disconnects
Old Apr 16, 2009 | 01:28 PM
ArrowheadRay's Avatar
Default Front sway bar quick disconnects
Tomorrow I get my lift, wheels and 33's installed. I think my next mod will be front sway bar quick disconnects. I was thinking about the TeraFlex Quick Disconnects to go along with my 2.5" Teraflex BB, but they don't look as beefy as others out there. Can I install any brand or should I stay with the same brand as my lift? If I can install any brand which do you guys recommend?
Thanks.
Old Apr 16, 2009 | 01:58 PM
Calypso's Avatar
Any made for the JK will work. Just make sure you get adj or the right length for your lift. I'd go with TF or JKS.
Old Apr 16, 2009 | 02:25 PM
I really like the way the JKS look. The skyjackers look pretty nice as well.
Old Apr 16, 2009 | 02:28 PM
dremex's Avatar
I went with the TF because it came with that handy bracket so you can attach the link and get it out of the way without having to use a zip tie or other method. They work great!
Old Apr 16, 2009 | 03:40 PM
That's sounds pretty good to me...no bungees is always a good thing. The only reason I was wondering about the TF is because of the pics that I've seen. They just look a little wimpy compared to most of the others.
Thanks for the info guys.
Old Apr 16, 2009 | 03:48 PM
nthinuf's Avatar
JKS Quicker disco's here. Easy to take off/store/put on.
If you don't already have them, consider extended bumpstops when you get the disco's...
Old Apr 16, 2009 | 04:12 PM
greenryde's Avatar
I have the teraflex quick disco's they work great and easy to use
Old Apr 16, 2009 | 06:05 PM
dpoelstra's Avatar
TF for me too! Just use some Lock Tite on the threads. I had one work lose and I had no sway bar for a few weeks.
No problems since.
Old Apr 16, 2009 | 06:08 PM
doc307's Avatar
JKS here..
Old Apr 16, 2009 | 06:16 PM
StevieRay's Avatar
I got the JKS because of the design. I don't know the design of the Tera Flex, but the JKS is easy because you remove two pins then pull the disco all the way off the vehicle. No bungees necessary. I also like the adjustability to keep the sway bar parallel to the ground.
