tyres
Old Apr 20, 2009 | 12:21 AM
jeepinfrance's Avatar
Default tyres
it is the maximum size tire that can be mounted on an unlimited without having to make enhanced
escuse me translate english/french = google.
Old Apr 20, 2009 | 01:18 AM
zook's Avatar
I think people are using 285's on stock wheels and no lift.Hope this helps.
Old Apr 20, 2009 | 02:36 AM
Calypso's Avatar
You will be okay with 32" tires and some 33" tires if they aren't too wide (around 10 1/2") This would also be = to 285/70/17's.
Good luck.
Old Apr 20, 2009 | 05:33 AM
thank you for your reply
Old Apr 20, 2009 | 08:45 AM
nthinuf's Avatar
Browse the Wheels and Tires section when you get a chance. Lots of good info there in the FAQ's.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Old Apr 20, 2009 | 08:54 AM
riverzendz's Avatar
I've seen 33's on a stock 2 door. Granted, he had aftermarket wheels with a different backspacing.
Old Apr 20, 2009 | 09:21 AM
Calypso's Avatar
I actually ran 295/70/17 (33.5"x11.5") on stock suspension for about a week prior to my lift. I did have wheels with 4.5 back space though. The only rubbing I had was at full turn it would hit the plastic under the front bumper. I wouldn't off road that way at all. With stock rims it would be a bad deal.
Old Apr 20, 2009 | 09:45 AM
jeepnick's Avatar
im about to put the 29570r17 on my rubicon and dont want to lift it 4.5 backspacing, was it the over hang of the front bumper you hit? did you flex it at all? the other tire size option is 285/75/17 but thats a wider tire wouldnt that be worse?
Old Apr 20, 2009 | 10:05 AM
jeeperjkj's Avatar
The 285 would be narrower than the 295.
Old Apr 20, 2009 | 10:22 AM
Calypso's Avatar
It was the junkie plastic that covers the e-disco on the Rubicon. VERY LIGHT flex was all I attempted and it was okay but I never disconnected or got it in serious flex.
The 285/75 isn't wider, it's taller.
Here's the breakdown: 285/75 295/70
sidewall Ht= 8.4" 8.1"
width = 11.2" 11.6"
diameter= 33.8" 33.3"
