Help! Front pinion seal diameter????
Old Apr 29, 2009 | 04:44 AM
ullmenkott's Avatar
Default Help! Front pinion seal diameter????
Hi!
Does anyone know the inner and outer diameter of the front pinion seal on a JK Rubicon 2008?
I´ve changed the driveshaft´s and now I have a leak from my front pinion
Is it the same seal measurements for the seal in front as in rear axle?
Old Apr 29, 2009 | 05:32 AM
wayoflife's Avatar
JK-Forum Founder
changing out your drive shaft alone shouldn't cause your pinion seals to leak. now, if the new yokes you installed weren't installed properly and are a little loose, that will cause a leak as will a drive shaft that is vibrating.
Old Apr 29, 2009 | 05:34 AM
jonsjeep's Avatar
i agree. you gotta torque the hell out of em.
Old Apr 29, 2009 | 05:51 AM
ullmenkott's Avatar
Thanks guys,
I torqued the hell out of them
But as I saw the leak from the pinion in the front dif I also saw that there was a little tiny tear in the rubber ring/seal that goes around the yoke (so my guess is that that´s what´s causing the leak).
Is it enough just to replace the rubber seal or do I have to change anything else?
What´s the inner and outer diameter of that rubber seal?
There is no seal to be found in Sweden so I have a bit of a problem
