C-Gusset Chatter
Old May 1, 2009 | 11:36 AM
paramaniac's Avatar
Default C-Gusset Chatter
has anyone that has installed these noticed a "clanking" sound going over bumps? i can reproduce it easily by shaking the front end and ive been able to isolate it right to the the C Gussets on each side.
EVO guys, is there anything i can do? when i installed them we got them in real tight, and they looked just like the pics. im sure since ive had the roof open and doors off that i am noticing it more lately.
Old May 1, 2009 | 11:50 AM
mkjeep's Avatar
Probably hitting your frt springs, I know mine are really close.
Old May 1, 2009 | 11:56 AM
paramaniac's Avatar
Default yes indeedy
they are definitely hitting my front springs, no doubt in my mind. aside from grinding them off and re-welding, whihch i dont think will matter, what can be done.
or just live with it
Old May 1, 2009 | 12:03 PM
mkjeep's Avatar
I dunno, mabe contact EVO. Mine don't chatter, my transfer case, gears, locker or something is chattering not the EVO's. At least not yet, been without my jk for over a month, who knows, that maybe clanking next.
Old May 1, 2009 | 12:08 PM
mkjeep's Avatar
Paramaniac, You have a BB, do you have adj trk bar or bracket? If not your axle is off center and maybe causing one spring to bow out more than the other
Old May 1, 2009 | 12:17 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Just FYI Mel is currently on the Detroit Locker Tour up in Oregon so you may not recieve a response on here till they're back. Call the shop, Andrew can probably assist you. Good luck
Old May 1, 2009 | 12:20 PM
greenamphibious's Avatar
he is running the 2" SJ.... I bet you hit the nail on the head right there! Just enough offset to hit the spring
Old May 1, 2009 | 12:24 PM
paramaniac's Avatar
I got rid of my BB, am running the OME HD springs as I blew out my stock springs.they are giving me about 3.5" of lift though. I do have adj track bars on my to get list but my dead, and I mean dead, stock springs needed to go first
Old May 1, 2009 | 12:27 PM
then you are even further out of axle alignment. If you have the gussets installed right, the next step would be at minimum a front adj trac bar
Old May 1, 2009 | 12:31 PM
RedneckJeep's Avatar
I know this is gonna sound slap ridiculous.....but IF you're SURE the spring hitting the gussett is where the noise is coming from, just run a small bead between the gussett and spring. Small enough to grind off easily yet large enough to do the job. Problem solved. IF that's what it is.
