Need help with TF 2.5" lift
Old May 2, 2009 | 08:09 PM
Richs07's Avatar
Default Need help with TF 2.5" lift
Ok everything was going fine untill I got to the relocation bracket for the track bar When I put the bracket up into the factory bracket the holes are about 1/8" off with the bracket bottomed out
Old May 2, 2009 | 08:33 PM
DPJK's Avatar
Default I feel your pain
This is a known and common problem with the teraflex track bar relocation bracket. People have come up with different solutions from putting the bracket in a vise, to drilling the holes out a little bit.
I drilled the hole out a little bit on mine. Just enough to get the bolt through using my BFH. May not have been the best solution, but it worked for me in the time/frustration level I had.
Good luck, and if you search the threads you will find how others have dealt with this known problem.
Old May 2, 2009 | 10:40 PM
Jmacaws's Avatar
There is a lot of info on these, I went with the TF axel mount track bar bracket. It's about a hundred bucks.
Old May 3, 2009 | 02:21 AM
RedneckJeep's Avatar
I put a floor jack and a piece of 2x4 under mine and jacked it up into place. Worked fine. I like the fact that it fits that tight. Absolutely no room for movement.
Old May 3, 2009 | 04:50 AM
Ryanc's Avatar
Good idea, I will have to remember that.
Old May 3, 2009 | 06:55 AM
Richs07's Avatar
thx i will try that so if i don't use the bracket my axle will just be off a bit right untill i get track bars, but no damage right
