Lug nuts on pro comp X alloys
Old May 5, 2009 | 08:27 AM
paranoid's Avatar
Default Lug nuts on pro comp X alloys
Just ordered some pro comp 17 x 9 7089, Will my stock lug nuts work on these or do I need to order The pro comp ones. Thanks
Old May 5, 2009 | 09:15 AM
greenamphibious's Avatar
if you have the acorn wheel lugs then they will work. There will be some washer/spacer thingys on around the wheel studs, make sure you pop those off to get the wheel flat
Old May 5, 2009 | 09:20 AM
Piginajeep's Avatar
You have to use the gorilla lugs that 4wd.com sells, they come in a 20 pack.
The stock lugs wont fit the rim correctly, on top of scraping your new rims, you can loose the wheel going down the road..
I fould out the hard way
Old May 5, 2009 | 09:23 AM
I have never used anything but oem alloy lugs on aftermarket wheels... never had procomps... what is the difference?
Old May 5, 2009 | 09:26 AM
Piginajeep's Avatar
they are smaller hole diameters, the stock lugs wont sit properly. Luckly I felt the tire start to shake and stopped. Soon as i did, the wheel fell off.
heres what you need
http://www.4wd.com/productdetails.aspx?partID=4794
Old May 5, 2009 | 09:36 AM
hmmm, good to know if I ever order procomps
Old May 5, 2009 | 09:40 AM
ScottK's Avatar
Is this only an issue on the Procomps? I was going to use my OEM lugs on my Walker Evans wheels.
Old May 5, 2009 | 09:42 AM
Piginajeep's Avatar
I believe so, gorilla makes the lugs specifically for the procomps.
Old May 5, 2009 | 11:05 AM
BaltChief's Avatar
I have the 7189's and used the stock lug nuts have I screwed up?
Old May 5, 2009 | 11:09 AM
archerc's Avatar
The Lug nuts that came with my 7089's had less bevel and were a little thinner. I havent had any problems with wheels coming off or anything, they do look better than the stock ones though.
