Drilling holes for bump stop mounting
Old May 30, 2007 | 07:27 PM
bim6180's Avatar
Default Drilling holes for bump stop mounting
HI All,
On WOL's suspension install instruction, for the front bump stop, he drilled a 11/32-diameter hole before putting through the 3/8 self tapping screw (this is an instruction for FT kit).
I've just ordered RE 2" BB kit, and for the bump stop, it also comes with 3/8" self tapping screw. HOWEVER, the instruction said to drill 5/16-diameter hole instead.
Am i missing something here? Any help would be appreciated. I don't want to drill a wrong hole
Old May 30, 2007 | 08:05 PM
Eracer76's Avatar
My RE 3.5" Super-Flex instructions said the same thing, to drill a 5/16" hole.
I did and it wasnt big enough, I couldnt get the self tapping bolt started, so I drilled it one size bigger and it worked fine
Old May 31, 2007 | 04:56 AM
IGOFSHN's Avatar
Originally Posted by bim6180
HI All,
The difference is 1/32???? It won't make a difference. RE is just using a more common drill bit.
Old May 31, 2007 | 06:44 AM
wayoflife's Avatar
JK-Forum Founder
HI All,
The 11/32" hole will just make it easier to tap it with the self-tapping bolts. You can still do it with a 5/16" hole, it just will take a lot more effort especially if all you've got are the self-tapping bolts to work with.
Old May 31, 2007 | 06:54 AM
bim6180's Avatar
Awesome... then 11/32" drill bit then
