Camber ?
Camber is an alignment issue that needs to be dealt with of IFS vehicles only. The Jeep JK Wrangler has a soild front axle and therefore a lift will not and cannot effect or change your camber.
A solid axle can have also camber, if the axle was rotated (caster), because the angle between the upper and lower ball joint.
