Need Help Diagnosing...
Old Jul 5, 2009 | 09:54 AM
Phishjeep's Avatar
Default Need Help Diagnosing...
...a soft clicking sound coming from the front when I turn right only. It mainly occurs when going slow and turning quite a bit, but now I've convinced myself I hear it at speed sometimes. I tried the wheel bearing test (jack up and wiggle the top and bottom of the wheel, but no movement occurred). Is that still a possibility? I have about 43000 miles, including about 5000 since my 35's went on. Thanks!
Old Jul 5, 2009 | 10:21 AM
mkjeep's Avatar
Have u checked your axle u-joint caps?
Old Jul 5, 2009 | 10:30 AM
Phishjeep's Avatar
No. How would I do that?
Old Jul 5, 2009 | 10:35 AM
mkjeep's Avatar
Look at the front axle close to where your tire is underneath your jeep. Where the C on your axle end is, there is a shaft that comes out and has a u-joint on it . I'll look for a pic.
Old Jul 5, 2009 | 10:42 AM
mkjeep's Avatar
This is one with the caps tack welded. These caps have been well known to come off and cause axle damage.
Old Jul 5, 2009 | 11:27 AM
paramaniac's Avatar
Attachment 26476
i dont have an issue with that, but have read that many guys and gals do... ill be checking mine when i get a free minute
Old Jul 6, 2009 | 12:31 AM
Phishjeep's Avatar
Nope, those are good. Anything else?
Old Jul 6, 2009 | 08:45 AM
eDiveBuddy's Avatar
This may sound silly, but check the right sides of both tires for a rock embedded in the tread.
Old Jul 6, 2009 | 09:08 AM
Ryanc's Avatar
Mine does the same thing when it is really warm outside. It goes away during the cooler months. Have never been able to figure it out.
Old Jul 6, 2009 | 09:15 AM
eDiveBuddy's Avatar
Does it go away or is it that you just put the top back on
