View Poll Results: What material is best for spacers?
Aluminum (Spidertrax)
9
100.00%
Steel (Teraflex)
0
0%
Voters: 9. You may not vote on this poll
Aluminum vs Steel Wheel Spacers
Old Jun 3, 2007 | 11:48 AM
JKDude07's Avatar
Default Aluminum vs Steel Wheel Spacers
I am looking at the spacers for the JK:
1. Spidertrax-Aluminum 1.25 inch or
2. Terraflex-Steel 1 inch
The price is about the same, so which would be better with stock Sahara rims?
Old Jun 3, 2007 | 12:14 PM
LidLess07X's Avatar
I did not vote because I don't really know which one is "better", but I have the Spidertrax and I am very pleased with the quality. Only thing is , I would get extra loctite because I don't think they give you enough.
Old Jun 3, 2007 | 12:24 PM
armycop's Avatar
Go with aluminum for lighter weight and corrosion resistance.
Old Jun 3, 2007 | 12:48 PM
usmcdoc14's Avatar
first part yes, 2nd part no
aluminum+ salty roads = suckage
aluminum + steel = dissimilar metal corrosion
I would run the aluminum ones, less unsprung weight is ALWAYS better and its not like you are going to kill them. I have never seen an aluminum one fail.
Old Jun 3, 2007 | 02:34 PM
trucco's Avatar
I also have the Spidertrax and they work great for me. Besides, I'm very pleased with the quality and how they just bolt in.
Old Jun 3, 2007 | 02:57 PM
JKJoe's Avatar
Strength and weight, aluminum all the way. I had no idea companies still used steel. Nothing I would run, no reason to when the aluminum ones are just as strong, if not stronger. Also, the Spidertrax spacers are anodized for protection from the elements. I have had my Spidertrax for a little while now, and zero issues.
Old Jun 3, 2007 | 03:05 PM
Renegade's Avatar
I know that the Teraflex info says that they are steel, but they look like machined aluminum to me. Does anyone actually have any of these? Is this a misprint? Here's a pic:
Old Jun 3, 2007 | 03:17 PM
JKJoe's Avatar
I agree, but I did find this on Teraflex's website. Seems like all sites selling these use the same decription also. I would like to know though if it is a misprint too.
"The TeraFlex JK specific wheel spacer is designed for those desiring to retain their stock wheels, but use a larger tire. The wheel spacer increase track width to move the tire and wheel out for added clearance from FlexArms and body panels. These spacers also adapt the stock bolt pattern (5x5") to a 5x4.5?"or 5x5.5" bolt pattern for custom wheel selections.
The spacers are machined from solid steel and come with wheel studs pressed in. Additional lug nuts are included. "
