Sea Foam?
i used it on my old jeep with the 4.0 straight 6. had over 100,000 miles on it. the seafoam definitely smoothed out the idle and i felt a better throttle response. Not sure how it would work on a new motor
I can say that it will revive small engines that have been neglected or left sitting a long time with old gas.
I used it on my Justy (last carb engine car in US) when I bought it and it smoothed the idle out.
I currently use it in my motorcycle and also used it in my old Isuzu Rodeo (both over 100k miles).
With the motorcycle I use it in the fuel system to help cut down on the carbon buildup in the combustion chamber. I run about 1/2 a bottle through about every 10k miles, or if it ever starts pinging during hot weather
With the Rodeo, I dumped in into the oil and let it run for about 15 min. Then proceeded with an oil/filter change. It really helped quiet down the lifter tap in the motor. The Rodeo's were notorious for collecting engine sludge, and the Seafoam was the only thing I ever found that did a good job of cleaning it out.
