4 inch long arm + 35's
Old Aug 12, 2009 | 11:16 AM
Newjeepster's Avatar
Default 4 inch long arm + 35's
Hello I just ordered the rims/tires for my jeep. Once I got them in I will be able to install my 4" long arm Tera flex lift. Here is my question.
With the Mickey Thompson Rock Biter 17r x 9 rims + 35x12.50x17r <-- Baja Radial ATZ.
Should I worry with gearing its a 2d 2007 Hard top It's a manual transmission? 410 diffs atm.
Also should I worry about welding axle gussets on at the same time since it's a d30 front axle?
I'm not worried about doing things correctly that's why I waited to order rims to fit my 35's and not spacers. Also I want to make sure I don't break anything once I put it in some hairy situations. I am going to be doing trails mostly and I want to be able to rock crawl around and go over things. I try and avoid mud as much as possible but I do go through it when it is in the way of a trail I want to explore.
I would love any input that you guys will have. Oh on the 4" long arm I have everything that is needed to install it etc along with drive shaft(s) etc. I'm just mainly concerned with the axle strength etc.
Many thanks for your time and consideration
*edit* Sorry i left off that it's a manual transmission and not an auto.
Old Aug 12, 2009 | 11:22 AM
mkjeep's Avatar
If it were me, at the very least, c-gussets and contol arm skidsand reinforce the trackbar mounts
Old Aug 12, 2009 | 11:26 AM
mkjeep's Avatar
Drive it with the 4.10's and see what you think. OD will be pretty much usless. I drove mine like that over a year before I regeared. If you want a slower crawl for rocks and have the$$$, then get some 5.13's
Old Aug 12, 2009 | 12:07 PM
john smack's Avatar
I have a 4dr with 35's and 4:10's and its alright, faster than a golf cart anyway
Old Aug 12, 2009 | 12:16 PM
What are the control arm skids? and reinforcement on the trackbar mounts?....
Old Aug 12, 2009 | 12:39 PM
mkjeep's Avatar
c-gusset and frt skid kit , There are also rear skids available, different kinds.
Old Aug 12, 2009 | 12:47 PM
mkjeep's Avatar
ID:	28461........ C-gussets
Old Aug 12, 2009 | 12:51 PM
mkjeep's Avatar
Track bar mount can be gusseted by a welder or you can buy them from different manf. Check this write up out
https://www.jk-forum.com/forums/show...rack+bar+mount
Old Aug 12, 2009 | 12:54 PM
rmdchewie's Avatar
My 07 Rubi has 35's and it's a little sluggish but not too bad. I can see a re-gear in my future once I get everything else taken care of. As for strength, I would look into upgraded axle shafts or an axle swap, I've broken my LF axle shaft twice now and that's with the 44.
Old Aug 12, 2009 | 03:01 PM
jkkat's Avatar
With RubyDoo and her 5:13's, she takes off like a ricer from a light when your trying and cherps second gear tooo.........
