Trackbar help
Old Aug 15, 2009 | 04:01 AM
GrimsbyAl's Avatar
Default Trackbar help
I put front and rear JKS adjustable trackbars on my jeep. I noticed when I put the front one on, the diameter of the mounting bolt on the axel side seem much smaller than the the diameter of the hole on the axel bracket and trackbar maybe 1/8 of inch or a little more. the jeep was brand new and I am the only one who has ever worked on it, it this normal?. My concern is the axel shifting a little over time and screwing up the bracket hole on the axel.
If this is not normal can anyone tell me the the diameter and length of the bolt so I can pick up a larger bolt on my whay home from work today. I'm at work now and don't have my Jeep with me or I would do it myself.
thanks
AL
Old Aug 15, 2009 | 05:30 AM
Ryanc's Avatar
thanks
AL
Your fine, if I am reading your post correctly. 9/16 grade 8 will be just a hair wider and give you a better fit.
Old Aug 15, 2009 | 06:12 AM
GrimsbyAl's Avatar
so a 9/16 will be a little larger (diameter) what length? I don't have access to mine to mesure it right now and I would like to pick it on my way home from work.
AL
Old Aug 15, 2009 | 06:34 AM
Hellbound13's Avatar
This is what happened to me. Wallowed out both mounting holes front and back. I had to weld grade 8 washers and switches to 9/16 shouldered bolts. Much better now. Why jeep didn't use shouldered bolts is beyond me.
Old Aug 15, 2009 | 08:21 AM
GrimsbyAl's Avatar
can anyone tell me the length of all the trackbar bolts I want to relpace all of them, and want to pick them up on my way home from work.
Old Aug 15, 2009 | 08:27 AM
mkjeep's Avatar
9/16"x 3 1/2"
Old Aug 15, 2009 | 08:31 AM
mkjeep's Avatar
Oh btw, get locknuts for them. Or you could do like Hellbound and do locknuts,locktight,weld and rachet strap them.
Old Aug 15, 2009 | 08:37 AM
You forgot krazy glue.
Old Aug 15, 2009 | 08:42 AM
mkjeep's Avatar
Dammit, thought I had the complete list.
Old Aug 15, 2009 | 01:29 PM
rmdchewie's Avatar
You forgot the top 2, Duct tape and Vise Grips
