ignition kill switches
Old Jun 3, 2017 | 11:35 AM
jkzombiehunter's Avatar
Default ignition kill switches
Several thefts of Jeeps reported on TV in the San Diego area. Easy access to the engine compartment apparently makes it easy. Anyone suggest a effective ignition kill switch?
Old Jun 3, 2017 | 01:12 PM
TheDirtman's Avatar
I just use a full battery cut off placed on the negative side of the battery. https://www.summitracing.com/nv/parts/sum-g1432 I have this on my TJ https://www.summitracing.com/nv/part...-12v/overview/
Old Jun 6, 2017 | 12:36 PM
kejtar's Avatar
On my manual transmission XJ I had one tied into the clutch disconnect. I'm thinking about tying into the NSS on the JK. A well hidden switch inside the cab someplace might make sense
Old Jun 6, 2017 | 12:52 PM
jchappies's Avatar
Ravelco only way to go
Ravelco Anti Theft Device
Not one vehicle ever STOLEN . . .
by defeating a properly installed and utilized Ravelco!
Old Jun 13, 2017 | 09:15 PM
EHarris's Avatar
JK-Forum Ambassador
I went with a bolt hold lock for $50. I want some kind of switch also but I figured maybe just locking the hood was enough to keep them moving on.
Old Jun 14, 2017 | 06:05 AM
jchappies's Avatar
Locking the hood only keeps them from cutting the horn. You really need to stop them from starting it or from getting to the OBDII port
Old Jun 18, 2017 | 06:32 AM
EHarris's Avatar
JK-Forum Ambassador
Woah! I need that for my Baja trips. The second link with the remote starts, how difficult of an install is this? Looks almost too simple?
Old Jun 18, 2017 | 06:43 AM
TheDirtman's Avatar
Takes about 10 min to install. Its not a remote start, the remote triggers a relay in the box to connect and disconnect the battery. it also has a hot lead you can use for the radio or an alarm system that is not affected when you shut it off.
Old Jun 18, 2017 | 08:38 AM
EHarris's Avatar
JK-Forum Ambassador
Yea sorry not remote start but essentially turn on and off.
I'm making my own circuit breaker/SPOD type device. I am putting in a water proof enclosing, so maybe I can somehow fit this in.
Old Jun 20, 2017 | 04:37 AM
Bradlybob's Avatar
Veteran: Navy
I read the other day that they had busted the San Diego Jeep theft ring that was working out of Mexico.
Feds bust Hooligan motorcycle gang for high-tech auto theft ring | fox5sandiego.com
