Indian Truck Trail to Cooks Corner by way of Main Divide?
Has anyone ran the trail from Indian Truck Trail off the 15 to Cooks Corner (El Toro/Santiago)?
Looking to do this run. Map shows Indian Truck Trail to Main Divide to Maple Springs to Santiago Canyon. |
Was trying to remember why I had never been able to put this route together even though it shows it should go through (been a few years since I tried to get from one side of Santiago Peak to the other). I got out my forest service maps and verified with the current online FS maps. There is a gate between Main Divide and Maple Springs. The current online map actually shows two separate gates, a black gate at the end of Maple Springs and a red gate at Main Divide. Gates were always closed every time I tried. I would call the Trabuco Ranger station and verify that the gates are open before planning on it.
Originally Posted by OffTopic
(Post 3841059)
i dont have a map but this tells if the fire roads are open up there...
Cleveland National Forest - Alerts & Notices |
I don't think you can, I did Santiago peak to Sierra peak (north main divide) thinking I could exit somewhere near there and every gate was locked. One road dumps you into a neighborhood in corona, one is black star, and the other was locked by the private property antenna area near Meeks place. I had to come all the way back and exit at Santiago canyon where I started.
Yeah that's just it, even though the trails are open, the gates between them are often closed. Every single time I tried from either direction the gates were closed...but that's my luck.
Here's the on-line map that shows the two gates between the trails that I mentioned are the problem. You have to download it (Northern Portion), can't view online, but it's a much better map than any other you'll find online for that area. Region 5 - Geospatial Data |
I have not seen Indian Truck Trail gate open for years. New construction at the base makes it harder to find the trailhead. You have to go through some new housing and take a dirt road to west.
I've run the trail twice in the last year and the Indian Truck gate is closed where it meets Main Divide. The first time I started at Indian Truck Trail (i used to live in that track). I had to turn around at the top. The second time I stopped and asked the Rangers in Corona who said all the gates should be opened. Not wanting to have to turn around again I started off of Ortega and saw the gate for Indian Truck was still locked. I think that gate is permanently locked.
Time to order bolt cutters on amazon.
Originally Posted by twofourflinching
(Post 3843786)
