Moving to SOCAL
Ditto, I have four (4) lights on my Body Armor front bumper that have remained uncovered since I got them, and I have never been questioned about it.
Russ D.
This is all good information. Thanks everyone for contributing. Vernnz, I don't think you will find me at RSC. Been there and done that and got the shirt. I'll be sitting at CSC or CSOOW. It looks like maybe the Milius.
Keeping it registered in Florida will avoid the inspection and fees.
Again...If you run one plate you will get stopped at the gate, the gaurd will walk to the back and check the rear plate. If the rear is a 2 plate state, you will get scraped (instantly!!!) and turned around. If it is a 1 plate state they will wave you in. They have all of the states memorized.
FWIW most people I see roll with their lights uncovered.
Which DDG? I visit most of them from time to time. I am normally around TIC and IDS. One day when you're sitting RSC I might tap you on the shoulder.
They must be covered.
Foglamps
24403. (a) A motor vehicle may be equipped with not more than two foglamps that may be used with, but may not be used in substitution of, headlamps.
(b) On a motor vehicle other than a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 30 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
(c) On a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 40 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
Auxiliary Lamps: Off-Highway Use
24411. Notwithstanding any other provision of law, a vehicle may be equipped with not more than eight lamps for use as headlamps while the vehicle is operated or driven off the highway. The lamps shall be mounted at a height of not less than 16 inches from the ground, or more than 12 inches above the top of the passenger compartment, at any place between the front of the vehicle and a line lying on a point 40 inches to the rear of the seat occupied by the driver, shall be wired independently of all other lighting circuits, and, whenever the vehicle is operated or driven upon a highway, shall be covered or hooded with an opaque hood or cover, and turned off.
24404. (a) A motor vehicle may be equipped with not to exceed two white spotlamps, which shall not be used in substitution of headlamps.
(b) No spotlamp shall be equipped with any lamp source exceeding 32 standard candlepower or 30 watts nor project any glaring light into the eyes of an approaching driver.
(c) Every spotlamp shall be so directed when in use:
That no portion of the main substantially parallel beam of light will strike the roadway to the left of the prolongation of the left side line of the vehicle.
That the top of the beam will not strike the roadway at a distance in excess of 300 feet from the vehicle.
(d) This section does not apply to spotlamps on authorized emergency vehicles.
(e) No spotlamp when in use shall be directed so as to illuminate any other moving vehicle.
Foglamps
Foglamps
Thank you! It appears I am illegal then considering that I aimed my lights to be equal level with my high beams, but with a much wider reach so that I have FULL and distant effect while offroad with all 6 lights. While mine aren't "covered" they are protected, and only used off road or on pitch black country roads in place of highbeams, but are immediately turned off on approach of oncoming traffic (rare on road use!). At least I know when I am in the wrong, and that clarifies a lot. Thanks Sgt.
Fenders / Mud Flap Violations
27600. No person shall operate any motor vehicle having three or
more wheels, any trailer, or semitrailer unless equipped with
fenders, covers, or devices, including flaps or splash aprons, or
unless the body of the vehicle or attachments thereto afford adequate
protection to effectively minimize the spray or splash of water or
mud to the rear of the vehicle and all such equipment or such body or
attachments thereto shall be at least as wide as the tire tread.
This section does not apply to those vehicles exempt from
registration, trailers and semitrailers having an unladen weight of
under 1,500 pounds, or any vehicles manufactured and first registered
prior to January 1, 1971, having an unladen weight of under 1,500
pounds.
Fenders must cover the tire and generally the mud flap / splash guard will hang about an inch or two below the center of the axle , thats why why stock cars such as hondas toyotas have them and stock toyotas trucks have them off the lot as standard equipment.
Also for those of you with a Stinger Bimper....
Front Bumper
35408. In no event shall a front bumper on a motor vehicle be constructed or installed so as to project more than two feet forward of the foremost part of either the fenders or cab structure or radiator, whichever extends farthest toward the front of such vehicle.
Front Bumper
Frame and Floor Height
24008.5. (a) No person shall operate any motor vehicle with a frame height or body floor height greater than specified in subdivisions (b) and (c).
(b) The maximum frame height is as follows:
[This table lists the maximum frame height for various types of vehicles.] * Vehicle Type Frame Height
(1) Passenger vehicles, except housecars 23 inches
(2) All other motor vehicles, including housecars, as follows:
Up to 4,500 pounds GVWR 27 inches
4,501 to 7,500 pounds GVWR 30 inches
7,501 to 10,000 pounds GVWR 31 inches
(c) The lowest portion of the body floor shall not be more than five inches above the top of the frame.
(d) The following definitions govern the construction of this section:
(1) "Frame" means the main longitudinal structural members of the chassis of the vehicle or, for vehicles with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle.
(2) "Frame height" means the vertical distance between the ground and the lowest point on the frame, measured when the vehicle is unladen on a level surface at the lowest point on the frame midway between the front axle and the second axle on the vehicle.
(3) "GVWR" means the manufacturer's gross vehicle weight rating, as defined in Section 390, whether or not the vehicle is modified by use of parts not originally installed by the manufacturer.
* The bracketed information has been added editorially to meet accessibility requirements and is not part of statute.
Display of License Plates
5200. (a) When two license plates are issued by the department for use upon a vehicle, they shall be attached to the vehicle for which they were issued, one in the front and the other in the rear.
(b) When only one license plate is issued for use upon a vehicle, it shall be attached to the rear thereof , unless the license plate is issued for use upon a truck tractor, in which case the license plate shall be displayed in accordance with Section 4850.5. Amended Sec. 27, Ch. 594, Stats. 2003. Effective January 1, 2004.
Headlamps on Motor Vehicles
24400. (a) A motor vehicle, other than a motorcycle, shall be:
(1) Equipped with at least two headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches.
(2) Operated during darkness, or inclement weather, or both, with at least two lighted headlamps that comply with paragraph (1).
(b) As used in paragraph (2) of subdivision (a), “inclement weather” is a weather condition that is either of the following:
(1) A condition that prevents a driver of a motor vehicle from clearly discerning a person or another motor vehicle on the highway from a distance of 1,000 feet.
(2) A condition requiring the windshield wipers to be in continuous use due to rain, mist, snow, fog, or other precipitation or atmospheric moisture.
