need help with jeep problem
Old Apr 6, 2012 | 08:05 PM
OFP4LIFE's Avatar
Default need help with jeep problem
so i installed 4.88 gear in the rear and new rear axle shafts i took my front drive shaft off since i didnt finish the front so i can still drive. but my abs is engaging and not letting me drive. ill be finishing the gear tomorrow and i dont know why this is happening anyone run into this before????
Old Apr 6, 2012 | 08:08 PM
Captain Wild Thing's Avatar
Did you make sure the wheel sensors was installed properly?
Old Apr 6, 2012 | 09:30 PM
OFP4LIFE's Avatar
no the shop is installing and they said they did it right tomorrow im going to their shop to finish the fronts and fix the rear.
Old Apr 7, 2012 | 02:26 PM
willypapooh's Avatar
disconnect you abs, all for of the wires
Old Apr 7, 2012 | 03:49 PM
OFP4LIFE's Avatar
so the problem was the spacing on the abs sensor. it needed 4 washers where the bold holds the sensor so that it lines up with the abs ring. im so mad at nitro axles nothing mentioned the fact that the abs ring is in a inner location from stock.
i know i should have pressed the abs ring more out but i was tired of dealing with it.
Old Apr 7, 2012 | 07:49 PM
33 williys 77's Avatar
Sound like the Axle Shaft's needed alittle more machining
Old Apr 7, 2012 | 10:40 PM
lol, i dont even have tone rings on my axles.
Old Apr 8, 2012 | 09:14 AM
wildandwillin's Avatar
I just saw this or I would of said something I run the nitros and pressed in the ring on my press
Old Apr 8, 2012 | 03:20 PM
OFP4LIFE's Avatar
yeah i got the nittros because of you. when i was up there you highly recommended them
Old Apr 8, 2012 | 04:10 PM
Great axels and they stand behind them
