In need of mobile welder. Help
Jeep on city streets at my buddies house in Sierra Madre/temple city.
Track bar bracket broken.
Need mobile welder to weld it.
Thanks!
Drew
323-630-0642
Thanks!
Drew
323-630-0642
Phones plugged in it died....just got home.
Definently need to figure out what part is causing the death wobble or it will continue to break stuff...
Welds weren't the issue death wobble is, it can be nasty and will take stuff out....
The bent rim, bearings, worn arm bushings, ovaled out frame side tracbar mount, recheck for bearing play, ...
The pulsing and fact it hops 45mph when braking and the feel in wheel and pedal would make me look to rotors as well..a culmination of things can happen and after a few times can loosen other stuff as well...
The truss and tracbar are definently not the culprit, my guess is it was there and got aggitated o c's the front end got stiffened up...I can't think how a truss would effect it being its a ridgid piece and death wobble is slop somewhere....
And yeah I can see tracbar bracket taking a beating when the front gets wobbling I've seen brackets ripped off...death wobble can and is a beast...
Either way welds weren't the issue I will call mike and give him some stuff to address and look at ....its there somewhere and being overlooked....so we will add so e extra eyes and loo, harder.
it was good chatting with you and let's iron out the death wobble..
Welds are usually stronger than the metal its attached to. I've seen track bar brackets rip clean off from death wobble or hard hits. Big lows track bar ripped off at welds from abuse. I welded it back up I didnt do those original welds but the shear load removed it pretty damn clean.
Without knowing circumstances to this don't ask me to own up to this. Thanks for the input but there's ALOT more t it then thks...this happened because of other issues.
A tire doesn't go flat because it just lost air its a result of something else.
Death wobble will tear some stuff up, just to much energy going on that things won't take the beating especially when its been several cases of it.
As a foot note I'm more than qualified to find d a failure in welds, metal as well as discontinuities Internal fractures, colum load failures, cyclic failures, meta. Degradation of material thickness in pipes from friction ie ultrasonic pipeline inspection vka ulltrasonic etc.) NDT level II based on CWI (ultrasonic, magparticle' eddy, radiography, visual, dye etc)
