Ga laws posted: lift,mirrors, lights
Old Oct 16, 2008 | 08:36 AM
The Joker's Avatar
Default Ga laws posted: lift,mirrors, lights
here is a copy of some ga laws thight night come in handy!!
if you need anything specific, let me know.
TITLE 40. MOTOR VEHICLES AND TRAFFIC
CHAPTER 8. EQUIPMENT AND INSPECTION OF MOTOR VEHICLES
ARTICLE 1. EQUIPMENT GENERALLY
PART 1. GENERAL PROVISIONS
O.C.G.A. § 40-8-6 (2008)
§ 40-8-6. Alteration of suspension system; operation of vehicle with broken springs
(a) It shall be unlawful to alter the suspension system of any private passenger motor vehicle which may be operated on any public street or highway more than two inches above or below the factory recommendation for any such vehicle.
(b) It shall be unlawful to operate any private passenger motor vehicle upon any highway, roadway, or street if the suspension system of such vehicle has been altered more than two inches above or below the factory recommendation for such vehicle.
(c) It shall be unlawful to operate any motor vehicle upon any highway, roadway, or street if the springs relative to the suspension system are broken.
(d) Any person violating this Code section shall be guilty of a misdemeanor.
HISTORY: Ga. L. 1973, p. 458, §§ 1, 2; Ga. L. 1975, p. 763, § 1; Code 1933, § 68E-106, enacted by Ga. L. 1982, p. 165, § 4; Code 1981, § 40-8-6, enacted by Ga. L. 1982, p. 165, § 10.
O.C.G.A. § 40-8-6.1 (2008)
§ 40-8-6.1. Raised chassis vehicles
(a) As used in this Code section, the term:
(1) "Frame" means the main longitudinal structural members of the chassis of a truck.
(2) "Frame height" means the vertical distance between a level surface and the lowest point on the frame of a truck, measured when the truck is upon such level surface without a load.
(3) "Gross vehicle weight rating" means the manufacturer's gross vehicle weight rating whether or not the vehicle is modified by use of parts not originally installed by the manufacturer.
(b) It shall be unlawful to alter the suspension system of any truck with a gross vehicle weight rating of 4,500 pounds or less, which may be operated on any public street or highway, so as to exceed 27 inches as measured from the surface of the street to the lowest point on the frame of the truck.
(c) It shall be unlawful to alter the suspension system of any truck with a gross vehicle weight rating of not less than 4,501 pounds and not more than 7,500 pounds, which may be operated on any public street or highway, so as to exceed 30 inches as measured from the surface of the street to the lowest point on the frame of the truck.
(d) It shall be unlawful to alter the suspension system of any truck with a gross vehicle weight rating of not less than 7,501 pounds and not more than 14,000 pounds, which may be operated on any public street or highway, so as to exceed 31 inches as measured from the surface of the street to the lowest point on the frame of the truck.
(e) It shall be unlawful to operate any truck upon any highway, roadway, or street if the suspension system has been altered in excess of the limitations provided for in this Code section.
(f) Any person violating this Code section shall be guilty of a misdemeanor.
HISTORY: Code 1981, § 40-8-6.1, enacted by Ga. L. 1986, p. 1210, § 1; Ga. L. 1992, p. 6, § 40.
O.C.G.A. § 40-8-72
GEORGIA CODE
Copyright 2008 by The State of Georgia
All rights reserved.
*** Current through the 2008 Regular Session ***
PART 4. HORNS, EXHAUST SYSTEMS, MIRRORS, WINDSHIELDS, TIRES, SAFETY BELTS, ENERGY ABSORPTION SYSTEMS
O.C.G.A. § 40-8-72 (2008)
§ 40-8-72. Mirrors
Every motor vehicle which is so constructed or loaded as to obstruct the driver's view to the rear thereof from the driver's position shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle.
HISTORY: Ga. L. 1953, Nov.-Dec. Sess., p. 556, § 118; Code 1933, § 68E-403, enacted by Ga. L. 1982, p. 165, § 4; Code 1981, § 40-8-72, enacted by Ga. L. 1982, p. 165, § 10.
O.C.G.A. § 40-8-29
GEORGIA CODE
PART 2. LIGHTING EQUIPMENT
O.C.G.A. § 40-8-29 (2008)
§ 40-8-29. Spotlights, foglights, and auxiliary lights permitted
(a) Any motor vehicle may be equipped with not to exceed one spotlight, and no lighted spotlight shall be aimed and used upon any approaching vehicle. It shall be unlawful for any person except law enforcement officers and persons licensed under Chapter 38 of Title 43 to operate a spotlight from any moving vehicle on any highway or public roadway.
(b) Any motor vehicle may be equipped with not to exceed two foglights mounted on the front at a height not less than 12 inches nor more than 30 inches above the level surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of the high intensity portion of the light to the left of the center of the vehicle shall at a distance of 25 feet ahead project higher than a level of four inches below the level of the center of the light from which it comes.
(c) Any motor vehicle may be equipped with not to exceed one auxiliary passing light mounted on the front at a height not less than 24 inches nor more than 42 inches above the level surface upon which the vehicle stands, and every such auxiliary passing light shall meet the requirements and limitations set forth in this article.
(d) Any motor vehicle may be equipped with not to exceed one auxiliary driving light mounted on the front at a height not less than 16 inches nor more than 42 inches above the level surface upon which the vehicle stands, and every such auxiliary driving light shall meet the requirements and limitations set forth in this article.
HISTORY: Ga. L. 1953, Nov.-Dec. Sess., p. 556, § 111; Code 1933, § 68E-210, enacted by Ga. L. 1982, p. 165, § 4; Code 1981, § 40-8-29, enacted by Ga. L. 1982, p. 165, § 10; Ga. L. 1983, p. 3, § 29; Ga. L. 1992, p. 6, § 40.
Old Oct 16, 2008 | 09:15 AM
07JKX's Avatar
good post... but better that those laws are not enforced unless you fail to take the advice in in the book called:
"Don't Piss Off the Cops or They Will Find Every Possible Thing to Cite You With"
Old Oct 16, 2008 | 10:05 AM
tgrt's Avatar
Former Vendor
LA LA LA LA LA. I cannot hear you.
Old Oct 18, 2008 | 07:44 AM
dpost82's Avatar
most officers are not gonna take these laws into consideration unless like jarrod said your a total ass to the officer best advice i can give is always give the officer the most respect that you can and you should be fine
Old Oct 19, 2008 | 05:44 PM
kleinrider's Avatar
Old Oct 25, 2008 | 05:50 AM
ZoSo-Green's Avatar
Allright!
Everyone drop down to 2" and 33's.
And get rid of all those extra lights!
Old Oct 25, 2008 | 05:27 PM
jmc's Avatar
jmc
This is kinda good to know now that I just installed 2 driving lights on the windshield.
Old Oct 25, 2008 | 08:01 PM
jeepgeek2002's Avatar
its funny.. we have 3 cops in our club.. none of these guys even knew there was a law on that stuff.
goes to show how much they are strick on enforcing it.
mark
Old Oct 25, 2008 | 08:09 PM
The Joker's Avatar
the point of the post was so that you would have a copy of the laws so that if you get pulled over, for, say, having no doors or mirrors, you have a copy of the law to state that you are legal. my JK is too high for state law, but I haven't had a problem, but I have gotten pulled over for the doors off without mirrors. I got out of a ticket because of having a copy of this.
Old Nov 2, 2008 | 01:14 PM
WRAITHYJEEP's Avatar
wow so break the rules and what happens fine and correction order (fix it ticket)
do they impound
up here they can seize it for good if found to be modified in an unsafe manor.
