HELP D30 ring gear needed!
SOOOOOO, my saga continues! After I replaced my axles with upgraded ones from Alloy USA I desided to test them out before heading back to Hard Rock just to be sure everything was OK. Well, it's not. I herd the same grinding noise I herd before the U joint snapped. So, I pulled off the diff cover, cleaned it out and found that 3 of the ring teeth are broke, and several more are cracked! Plus, the axle seal on the passenger side is shot, and is leaking like crazy!
Dana 30 4:10 RING GEAR NEEDED!!!!!!!!!
Hey check this thread out, pm him see if he still has em, I can get someone to pick them up in NJ and ship them if he wont, it doesnt seem like he wants to be bothered shipping
https://www.jk-forum.com/forums/jk-axles-gears-drivetrain-118/4-10-gears-front-rear-79459/
