need help in birmingham!!
Old Jun 11, 2009 | 07:15 AM
smbundy13's Avatar
Default need help in birmingham!!
ok, i am desperate to turn off the esp in my 07 2 door. i have already gone to the dealership and had them flash the computer but i still cant get it to turn off.. anybody in birmingham or surrounding areas that would be willing to come and help me do this? please.
Old Jun 11, 2009 | 11:01 AM
ink42o's Avatar
it tells you how in your owner manual
Old Jun 11, 2009 | 11:03 AM
smbundy13's Avatar
yes i realize that but it hasnt been working.
Old Jun 11, 2009 | 04:04 PM
ink42o's Avatar
then your not holding your mouth right.... it worked fine with mine
Old Jun 11, 2009 | 07:26 PM
JK-Rubi's Avatar
This is fairly basic, but just in case I'll describe one possible issue. After I helped a friend install his adjustable front track bar, we jumped in his JK for a test spin around the block. ESP went crazy - kept applying brakes and we were just driving down a road that was straight as an arrow. Turns out that the ESP system is very sensitive to steering wheel alignment. If it's not close to centered, then you may have problems. After we adjusted the steering wheel alignment, all was good.
Even corrected an issue that he would occasionally experience when he drove around a freeway cloverleaf (Edit: This was prior to the adjustable track bar install). If he went into the initial curve just a hair too fast, on would come the brakes. That was with a 2" budget boost lift. Again, after the alignment - goodness.
Hope your solution will be this simple.
Old Jun 11, 2009 | 07:32 PM
JK-KJ's Avatar
Even corrected an issue that he would occasionally experience when he drove around a freeway cloverleaf. If he went into the initial curve just a hair too fast, on would come the brakes. That was with a 2" budget boost lift. Again, after the alignment - goodness.
Had the same issue with mine....re-centered steering wheel and all was good as well.
Old Jun 12, 2009 | 11:25 AM
smbundy13's Avatar
i have the procal and have set the steering wheel with it so it is straight, still get some activation. i might jsut say screw it and do a toggle. havent quite decided yet.
Old Jun 14, 2009 | 06:13 PM
smbundy13's Avatar
the procal tells me when the steering wheel is exact center. so that when i realign i am positive that the steering wheel is centered. so the wheel is centered.
Old Jun 16, 2009 | 10:39 PM
EXTREMEG's Avatar
I need to get over to the dealer to get mine flashed. might do it today seeing how the sun will be back out...
Old Jun 18, 2009 | 07:55 AM
smbundy13's Avatar
dont go to don drrennon. i have suspcions that nothing was done and they took my $85.
