Sponsor Video Presentations Sponsors only videos please in the forum.
View Poll Results: Is it the TIPM
TIPM ?
0
0%
TIMP?
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
help with electronic problems
Old Apr 19, 2025 | 12:32 AM
soto35's Avatar
Default help with electronic problems
Greetings, I have a problem with my Jeep Wrangler JK 3.8 2011 and it is that in 24 hours the battery runs out, this is the third battery I buy, I bought TIPM a month ago and the problem ended, but these days it started again with the same problem, I did the test of removing fuses by fuse verifying where the fault comes from and nothing happens, let me explain, with the voltmeter I did the test, I removed the positive cable that goes to the alternator and it is not the problem, I disconnected all the accessories lights, radio and the positive cable of the alternator for 24 hours and it still consumes the battery, have you had this problem? could it be my fuse box (TIPM)
Old Aug 16, 2025 | 01:10 PM
metjipo's Avatar
Veteran: Canadian Forces
I had a similar drain issue on my 2010 JK and it turned out to be a faulty ground connection that wasn’t obvious at first. Might be worth double-checking all grounds before replacing the TIPM again.
Old Aug 16, 2025 | 01:20 PM
soto35's Avatar
gracias lo voy a verificar
