Sponsor Video Presentations Sponsors only videos please in the forum.
TeraFlex: The Falcon 2 Series Mono Shocks
Old Nov 4, 2016 | 10:07 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Default TeraFlex: The Falcon 2 Series Mono Shocks
https://www.youtube.com/watch?v=FDuFEV0fW4E More info here: https://teraflex.com/shop/category?u...9C%93&q=falcon
The Falcon Series 2 Monotube Shock is designed to deliver the performance and handling requirements of the Jeep Wrangler in a compact and affordable package. The 6061 aluminum hard anodized body protects the internal components from damage and provides superior heat dissipation for consistent performance. The single tube design incorporates an oil/gas separator to prevent cavitation during rapid shock cycling. Falcon shocks feature Lucas Oil full synthetic shock oil for superior performance across all temperatures to reduce shock fade. The proprietary synthetic formula also contains special anti-wear and lubricity agents that produce excellent thermal stability.
Features & Benefits
- JK specific shock
- Increases vehicle stability
- Improved dynamic roll control
- Improved low speed damping
- Optimized fitment for clearance during full suspension travel & articulation
- Front offset stud design creates additional frame clearance
- 2.25” shock body provides optimal performance
- Largest shock body that will fit without modifications
- 6061 aluminum hard anodized shock tube resists wear
- Smooth honed internal shock body surface for long term performance
- ¾” shaft to prevent shaft buckling
- Maximum shaft diameter for optimal performance range
- Hard chrome, induction hardened shaft resists rock damage and corrosion
- OGS – the oil/gas separator prevents cavitation
- Digressive linear piston & base valve technology
- One-piece Teflon bronze piston wear band with o-ring
- Hard anodized billet piston
- Aluminum construction for superior heat dissipation
- Lucas Oil full synthetic shock oil
- 1,000 hour salt spray corrosion resistance on all hardware
- Fitment & function is the highest priority
- Serviceable & rebuildable (factory serviced)
- Built in-house at the TeraFlex Falcon shock division
- Fits all JK Wrangler models including Rubicon and Unlimited
- 3 year warranty
Old Mar 1, 2017 | 04:37 PM
ldstruckn's Avatar
Vet Army
Really interested in the set and a stabilizer however my newest Quadratec say unlimited only. I have a 2012 2 door. Why wouldn't they work on a 2 door?
