$100 Off INSTANTLY On Rampage JK Fender Flares!!
Old 05-13-2016, 10:55 AM
Sponsoring Vendor
Morris4x4Center's Avatar
Default $100 Off INSTANTLY On Rampage JK Fender Flares!!
Rampage FX Flat Style Fender Flares
Price (Textured) $612.99 (Black) $547.99
Click here to order
From now until May 31st, save $100 instantly on the purchase of Rampage FX fender flares!
The Rampage FX Flat Style Fender Flares provide a low-profile, built-in appearance that'll also allow you to fit larger tires on your Jeep. These fender flares shield your paint from road debris. They also feature an inner liner that fully encloses the underside of the flares. This provides a clean look and protects exposed sheet metal in the wheel well. They are 1" wider and offer 1.5" more clearance than stock fender flares. These fender flares are made from Tri-Flex ABS thermoplastic that provides maximum durability and a hard-to-scratch surface. It'll bend without shattering and is UV-protected. They come in a textured black finish with black hardware and are backed by the manufacturer's lifetime limited warranty. These easy-to-install fender flares require no drilling and mount to the existing factory drill holes.
Quick Reply: $100 Off INSTANTLY On Rampage JK Fender Flares!!
