85 Piece Socket Set. Dont Leave Home Without It!
Old Sep 4, 2012 | 07:16 AM
Morris4x4Center's Avatar
Sponsoring Vendor
Default 85 Piece Socket Set. Dont Leave Home Without It!
85-Piece Ratchet and Socket Set M-HM85
85 Piece S.A.E. & Metric Socket Set
Product Information:
GreatLite 85 Piece Socket Set in Zipper Case Includes: Twenty Three 1/4 inch Drive Sockets in SAE and Metric Sizes Eighteen 3/8 inch Drive Sockets in SAE and Metric Sizes 3/8 inch Drive Reversible Ratchet Handle 3/8 inch Drive 3 inch Extension Bar 3/8 inch Drive 5/8 inch Spark Plug Socket 1/4 inch(M) x 3/8 inch(F) Adapter Ratcheting Screwdriver Handle Twenty Assorted Screwdriver Bits, 2 Bit Holders SAE and Metric Wrench Sets with Holders Nylon Zipper Case. Comes with lifetime warranty.
Don't miss out on this super affordable 85 piece socket set.
Hi-Lift Cast and Steel Jacks
http://www.jeep4x4center.com/hi-lift-cast-steel-jack-36-hl364.html
Product Description:
Hi-Lift Cast and Steel Jacks have four stamped high-strength steel parts in combination with the cast parts. The top winch connector clamp is supplied standard with all Hi Lift jacks and each jack is fitted with a safety shear bolt which prevents the jack from being used on loads greater than 7000 pounds.
Product Details:
Standard Top Winch-Connector Clamp
Powder Coated Finish with zinc-plated hardware
2-Piece Handle & Socket for Reliability and Durability
7000 pound tested load capacity
Finish: Red Powder Coat
Overall Length: 41" Inches
Max Lift Height: 27" Inches
Weight: 25 Lbs.
