Bushwacker Flat Panel Flares $65 off and Free Shipping
#42
#43
Former Member
Yes I should be able to get just fronts. But Bushwacker is typically not gentle on the pricing for them. Often they would be about 2/3 the cost of the whole kit just for fronts. Also you have to catch them when they run the production on the fronts, or you may wait awhile.
#44
On the rebate form it states:
Rebate Rules:
Purchase any set of Flat Style Fender Flares from Bushwacker
(Part Numbers 10919-07, 10918-07 or 10920-07) and submit
the rebate form with proof of purchase by January 31st,
2010 to receive a rebate. Rebate values are as follows - Part
Numbers 10919-07, 10918-07 are eligible for a $50.00 factory
rebate and 10920-07 is eligible for a $25.00 factory rebate.
One rebate per customer. Valid in the U.S. and Canada only,
unless prohibited in your area. Proof of Purchase including
your original purchase receipt and product UPC required to
be submitted with rebate form. Be sure to make a copy of the
purchase receipt for your personal records. Rebate will be
distributed in US Currency.
Questions?
Call Bushwacker
Is this rebate valid if I order today?
Rebate Rules:
Questions?
Call Bushwacker
#45
Former Member
It would be valid if you ordered today.
Now it also says order by March 31st to get the rebate??? Now I am confused as well. I was under the impression when talking with the Bushwacker rep the it ran through March. I called our rep and hopefully he calls me back today.
#47
***From Previous Post***
Put mine on a couple weeks ago. 4WD had them 10% off and Bushwacker had a $50 mail in rebate. Bushwacker is handling the rebate direct, had my rebate check within 2 weeks.
They are just as wide as stock and have a nice texture (close to stock flares). They are pretty sturdy, you cant sit on em but they are just as sturdy or more than stock. Im sure the body will give before the flares do. The plastic mounting brackets are bolted on the front thru existing holes. The rear are bolted/plastic rivet to the rear of the body thru existing holes. The flares attach into the plastic mounts with screws and metal threaded pinch nuts. 1st flare takes the longest but after that you can fly thru the installation. Just make sure to take care when cutting the interior lining. They mean it when the instructions say "to much and they wont fit under the flares and to little and they will show the body". The side markers are LED and look pretty cool.
Side note: dont let them fall off and hit a broomed finished concrete, they will scratch. I did it (insert here). Just keep a hand on em while you put a screw in.
I need bigger tires now 2. They DO NOT vibrate or flap @ 70mph.
hread ***
#48
Former Member
#49
That means no long wait time to get your money! Had mine in about 2 weeks (but you have to get off your lazy a*# and send it in)
