Clayton Off Road JK Long Arm Upgrade Kits!
Old 05-17-2014, 09:54 AM
Sponsoring Manufacturer
Clayton Off Road Mfg.'s Avatar
Default Clayton Off Road JK Long Arm Upgrade Kits!
Clayton Off Road Inc. is known for building the ultimate in Jeep long arm kits and our new JK long arm kit is no exception. The lower arms use our tried and proven 2x2, ¼ wall square tubing and carry our lifetime warranty against bending or breaking.
Our new JK long arm kit is a 100% bolt on kit. One key feature with the new JK front long arm kit is our bolt-in 3 piece cross member. The cross member bolts into the OEM location and has pockets for the forged 2.5 inch johnny joints which allows for maximum ground clearance. This cross member can be simply bolted in, or it is also setup so it can be welded in for the more abusive drivers. Like all other Clayton Off Road cross members the center section is removable, making any transmission changes simple and can be done without touching any suspension arms. The rear ¼ bolt on bracket was designed to allow for 4 truly long arms. This bracket can be installed without removing the gas tank, and uses 8 bolts to securely clamp to the frame rail. Both the 3 piece cross member and rear frame brackets were designed using the latest 3D Solid Works program, CNC laser cut, and CNC bent for maximum strength and accuracy.
We have different kits for the 07-11 and 12+ model years, so make sure you select the correct kit for your application.
Alex
Marketing Director
Clayton Off Road
Old 05-28-2014, 06:36 PM
Here are a few pictures from Easter Jeep Safari showing how all of our control arms are constructed. If you have any questions let us know!
Find all of our long and short arm kits online at ClaytonOffRoad.com!
Alex
Marketing Director
Clayton Off Road
Old 06-21-2014, 09:04 AM
We are preparing another stocking order to send to Europe. If you are looking for any Clayton Off Road parts in Europe check out Offex.pl.
Alex
Marketing Director
Clayton Off Road
Old 08-20-2014, 01:00 PM
The guys on Truck U installed our 4.5" kit on a JK. Check out this Youtube video to watch them go through the install:
Alex
Marketing Director
Clayton Off Road
Quick Reply: Clayton Off Road JK Long Arm Upgrade Kits!
