Currie Extreme Duty Front & Rear Axle Assemblies
As many you know, Currie Enterprises has been a long time supporter of Project-JK.com under the capasity of Rock Jock through which they had been featuring their complete line of Jeep JK Wrangler Suspension Systems. Well, as of today, Currie Enterprises has decided to extend their support of Project-JK.com and JK-Forum.com by featuring their amazingly stout Rock Jock Dana 60 front and rear end assemblies. So, if you could, I would be grateful if you could please say hello once again and give Currie Enterprises another very warm welcome.
http://www.currieenterprises.com/ces...t.aspx?id=2996
Part #: JK-RJIIIF
Our Price:$4,999.95
Description: The RockJock III high pinion front end assembly for the 2007 and up Jeep JK includes the complete housing with the nodular iron housing center, AR400 heat treated bottom skid plate, 3" steel tubes, 1 ton inner knuckles, heavy steel cover, yoke, all heavy duty reproduction Jeep JK suspension brackets mounted, Currie performance forged alloy 35 spline inner and outer axle shafts, Spicer 1480 u-joints, 1 ton outer knuckles with Currie upper steering arms and ball joints installed, Currie exclusive 1 ton unit bearings with 5 on 5 1/2" wheel bolt pattern and JK tone rings installed to allow for ABS and ESP retention, zinc plated vented rotors with 5 on 5 1/2" wheel bolt pattern, caliper brackets that retain the stock JK front calipers, drive flanges or Warn premium manual locking hubs, and our heavy duty forged alloy tie rod with tie rod ends. The only parts needed to complete this unit is a high pinion 60 ring and pinion gear set, Dana 60 35 spline carrier of your choice, gear set up bearing kit, and your JK's stock calipers transferred over. Assembly labor of this unit is included in the price!
http://www.currieenterprises.com/ces...t.aspx?id=2997
Part #: JK-RJIIIR
Our Price:$1,899.95
Description: The RockJock III high pinion rearend assembly for the 2007 and up Jeep JK includes the complete housing with the nodular iron housing center, AR400 heat treated bottom skid plate, 3" steel tubes, heavy steel cover, yoke, and custom housing ends that accept set 80 axle bearings (over 50% greater capacity than stock) and allow for all factory disc brake hardware and ABS and ESP sensors to bolt back on. All new heavy duty reproduction Jeep JK suspension brackets are mounted and feature adjustable control arm mounting holes, adjustable trac bar mounting holes, and adjustable shock mounting holes. Also included are the Currie performance forged alloy 35 spline axle shafts that are dual drilled with the stock JK 5 on 5" wheel bolt pattern as well as the 5 on 5 1/2" wheel bolt pattern. Axles feature wheel studs, ABS tone rings, and axle bearings pressed on, as well as the bearing retainer plates. The only parts needed to complete this unit is a high pinion 60 ring and pinion gear set, Dana 60 35 spline carrier of your choice, gear set up bearing kit, and your JK's stock rotors, calipers, and caliper mounting brackets transferred over. Assembly labor of this unit is included in the price!
We will also be offering a small knuckle front 60 that will use all the stock outters. Should have pricing and product ready next month.
The rear end and 1 ton front end are now shipping!!!!!
Part #: JK-RJIIIF
Our Price:$4,999.95
Part #: JK-RJIIIR
Our Price:$1,899.95
Those are very hot.
