Does your JK lean?
Old Oct 7, 2008 | 03:50 PM
Evolution's Avatar
Sponsoring Vendor
Default Does your JK lean?
Over the past few years dealing with JK's on a regular basis, we have seen a few JK's lifted or not that have had a lean to one side or the other.
We have now come up with a solution that will help alleviate/basis the vehicle back to level.
Simply measure the swaybar links that you have on your vehicle from center hole to center hole. Purchase the length needed from our website. Install them and turn the linkage (gold hex bar in the middle) longer on the lower side of the vehicle. This will help bias the vehicles swaybar to compensate for the added side weight or whatever else is causing the leaning.
These can be used on the front and rear of the JK, with or with a lift kit. We offer linkage lengths from 5.5" - 15.9" in 1.4" adjustable lengths. These can be used on all JK Models (X, Sahara, Rubicon) but are not disconnectable.
The links are Heavy Duty 3/4" Solid Hex bar linkages, zinc plated with 1/2" studded teflon lined heim joints.
These can be used as heavy duty sway bar links.
This should only be used for vehicles that lean slightly. Severely leaning vehicles should check for other issues before installing.
Available Now.
More info here:
http://www.offroadevolution.com/stor...?prod=EVO-1036
EVO...
Old Oct 7, 2008 | 05:11 PM
wvextremist's Avatar
Is this considered severely?
Old Oct 7, 2008 | 05:25 PM
DeepSky's Avatar
Interesting solution. I got so sick of my Jeep leaning I put a 1/2" coil spacer on the passenger side.
Old Oct 7, 2008 | 07:31 PM
GOCACHN's Avatar
No...that's standard
Old Oct 7, 2008 | 08:01 PM
2drREDROCK's Avatar
Is this involving 4 doors only
Just wondering
Old Oct 7, 2008 | 09:23 PM
deconstructionist's Avatar
VERY interesting solution....and I love the look of them: but gotta say I'm glad I'm not suffering from the lean!
Old Jun 27, 2011 | 04:40 PM
MOKOS's Avatar
mine leans to the passenger side when the tank is full. When it's empty or half full it's a lot more level.
