EVO MFG Sector shaft brace
Old May 31, 2012 | 02:05 PM
EVO MFG's Avatar
Sponsoring Manufacturer
Default EVO MFG Sector shaft brace
With the installation of a lift kit with oversized tires and especially a dropped pitman arm, more side loading is presented on the Sector shaft on your steering box which in factory configuration is a single shear mount. Our EVO 1015 Sector Shaft brace is a bolt on item that double shears the shaft thereby helping to alleviate some of the side loading on this shaft.
•Bolt on installation (Drilling of two holes required)
•Double shears the sector shaft inside of the JK steering box
•Helps to alleviate side loading on sector shaft.
Old May 31, 2012 | 10:01 PM
Sunnysideup's Avatar
JK-Forum Ambassador
Mine works great... Good product!
Old May 31, 2012 | 10:24 PM
RedRockJeeper's Avatar
Looks good! On the list lol. Oh and Montana is the place to be. Lived in helena for 4 yrs absolutely loved it. Hopefully when I retire...
Old Jun 5, 2012 | 03:32 PM
EVO MFG's Avatar
Thank you!
Old Dec 8, 2012 | 11:35 AM
capthk's Avatar
Is anyone running this sector arm with the evo enforcer and draglink flip? I had to tighten down some loose bolts today and i was thinking about maybe adding this to my setup. Any of you guys have any feedback on it?
Old Dec 10, 2012 | 08:31 AM
RockIt Man's Avatar
x2 I plan running the same setup. Any comments?
Old Dec 10, 2012 | 08:34 AM
EVO MFG's Avatar
Two things
The sector shaft brace can only be used with a drop trackbar bracket (frame side).
Second, you dont need it if your dont have a drop trackbar bracket(frame side).
Old Dec 10, 2012 | 08:40 AM
RockIt Man's Avatar
Originally Posted by EVO MFG
Two things
The sector shaft brace can only be used with a drop trackbar bracket.
Second, you dont need it if your dont have a drop trackbar bracket.
Is this trackbar bracket frame or axle side?
Old Dec 10, 2012 | 08:45 AM
EVO MFG's Avatar
frame side
RockIt Man's Avatar
Sweet thanks for response! Placing an EVO order today!
