Free $100 Tread Lightly Membership
Old Jan 12, 2016 | 06:55 AM
Morris4x4Center's Avatar
Sponsoring Vendor
Default Free $100 Tread Lightly Membership
Purchase any select fridge/freezer, generator, or roof-top tent
and receive a FREE $100 Tread Lightly membership
Smittybilt Arctic Fridge/Freezer - 52 Quart (SB-2789)
Smittybilt Arctic Fridge/Freezer is ideal for tropical climates to keep beverages and other products icy cold out on the trail. This Smittybilt Arctic Fridge/Freezer has a 52 quart capacity, making it large enough for extended journey's into the backcountry. A three-stage automatic power cut off is incorporated to ensure that your vehicles battery has enough reserve capacity to start the engine. Smittybilt Arctic Fridge/Freezer has an ultra-efficient compressor that can run on 12 volt or 110 volts to provide temperatures as low as -22F in conjunction with thick 55MM polyurethane insulation. Price: $724.99
Smittybilt EPS Inverter Generator with Wireless Remote Start (SB-2786)
The all new Smittybilt EPS 2600W Premium Generator uses "3-Phase Inversion Process" inverter technology to provide, clean, quiet energy that is suitable for the most demanding requirements, including sensitive electronics. The EPS Premium Generator is rated at 2300W continuous/2600W peak operation, and is fully scalable using Smittybilt parallel connectors to link multiple EPS generators together for large energy needs. The use of Inverter technology dramatically reduces the size (L-24.2" x W-13.4" x H-19.9") and weight (~80 lbs dry) of the EPS 2600W Premium, making it exceptionally suited for use in campsites, RV's, cabins and other remote locations where power is not readily available. The Smart-Throttle system allows the engine to run at various speeds depending on load, greatly increasing fuel economy. The EPS 2600W Premium Generator holds 1.5 gallons of fuel, and is powered by an air-cooled 150cc 50-State EPA/CARB-Certified 4-Stroke OHV engine that is both quiet (53 to 63db max, depending on load) and efficient (up to 6 hours continuous operation at 50% load). The EPS 2600W Premium Generator is fully enclosed and is cased in a durable plastic housing with easy carry handle and rollers for easy positioning. The EPS has 2 120VAC and 1 12VDC outlets, Overload Protection, Low Oil Sensor, Parallel Cable Ports, Electric Start, and Digital Display for easy monitoring. Price: $799.99
Smittybilt Overlander Tent (SB-2783)
Smittybilt Overlander Tent offers the perfect camping solution for JK Wrangler owners. This complete tent set up features heavy-duty rip stop polyester, waterproof and polyurethane-impregnated top for the ultimate in durability. Anodized aluminum tent poles along with stainless steel hinges are perfect for whatever weather you may incur. Price: $799.99 (+$89/oversized freight)
Remember to use your forum discount code upon checkout!
Don't have a code yet? It's easy to get one! Just send us a PM!!
