Full Traction Long Arm Upgrade From 4Wheel Drive Hardware
Now Available!!!!!!!
Full Tractions 3-4" Long Arm Upgrade!
Fits both 2 and 4 door models, and will work with any 3-4" Full Traction short arm system!
Upgrade your existing 3" or 4" short arm kit to an awesome performing, true 4-Link Long Arm kit. All components in this suspension system are built for maximum off-road punishment. We use 2" x .250" wall DOM tubing for our lower trailing arm assemblies for serious rock dragging, and 1/4" plate laser crafted bracketry throughout. This is a FULLY BOLT-ON system. No welding is required to install.
#FTS7310 $1894.99
http://www.4wd.com/productdetails.as...0&partID=42554
Call or PM us if you have any questions!
800-333-5535
#FTS7310 $1894.99
800-333-5535
Here are the pics of the before and after. this is the 3 inch long arm on 35's
https://www.jk-forum.com/forums/jk-show-tell-33/3-fulltraction-long-arm-66308/
very nice, i helped install this kit on that rubi. the ride is better than factory. any question feel free to pm,email or call me.
This may be a stupid question....but dont you have to get rid of the stock mounting brackets on either the front or the back? And if so how tough was that? Im looking into this conversion but I want to make sure that I will be able to do it myself.
I hope this helps!
If you can use a grinder and drill, You can install this lift. After grinding the frame smooth. Slide the brackets in place, bolt them using the existing hole and drill the remaining holes on the brackets. You really cant screw up installing it.
thanks I really appreciate the input. Im fighting with myself right now on what project to jump on next. I really want to make my jeep ride better but to complete the short arms will cost me a good 800 and the long arm kit will hit the wallet harder but may be a worth while investment
I’m not trying to sell you with this statement. I’m just speaking to a Jeeper as a Jeeper!
Don’t waist your money on the short arm components, you will be happy with the short arm for a little while. But you will end up spending the money to get the long arm. This is just the gradual progression that Jeepers take, everyone you talk to that has done this will tell you that they should have just bought the long arm.
Again, not trying to sell you! I have personally taken this vehicle progression with my TJ and I regret the wasted money and time!
On topic, im deff looking at this as a possible upgrade.
Adam
Back on topic.
Adam you would be thrilled with the performace of a LA on your Jeep. It would take your wheeling experience to a whole new level.
