Holiday Prices On Select Viair Products
Old Dec 7, 2011 | 03:05 PM
ORWJK's Avatar
Sponsoring Vendor
ORW Representative
Default Holiday Prices On Select Viair Products
HOLIDAY PRICES ON SELECT VIAIR PRODUCTS
ID:	247026Click image for larger version
ID:	247027Click image for larger version
ID:	247028Click image for larger version
You aired down your tire at the trail head, spent the major part of the day on the trail, rocks, or sand and it's time to return to the campsite. There is a shortcut using the paved road, it will cut your travel time in half, you have been out in the sun, dirt and sand and looking forward to have a cold one and brag to your family about your off road escapades. The only thing is that you have to air up your tires to drive on the street. You remember that yesterday one of the members of your group aired your tires up at the end of the trail, but he went home this morning, what are you going to do???? As Off Roadies we like to be “Self-sufficient” when it comes to off road equipment. You have your own winch, your own CB Radio, your own tools, so this is an opportunity to have your own compressor!
ORW is offering deeply discounted prices on select VIAIR products including OBA systems. Fixed air systems (mounted on the vehicle) or portable air systems, VIAIR has the compressor for your specific needs.
On board Air Systems (OBA) are complete pneumatic systems intended to accomplish various tasks, depending on the kit selected. VIAIR offers OBA systems for smaller compressed air requirements that have a shorter duty cycle need, as well as other systems that provide up to 100% duty cycle and increased air volume by providing a larger tank for compressed air storage. Each On board Air System comes complete with compressor(s), air tank, fittings, pressure switch, relay(s), electrical connectors and all applicable accessories.
VIAIR 30033 Portable Compressor $145.00
The Viair 300P is a larger portable compressor kit that is capable of inflating up to 33-inch tires easily by simply clamping the power leads to your battery, connecting the tire chuck to valve stem and turning the unit on. The tire pressure can be monitored using the 5-in-1 inflater/deflater in line pressure gage.
VIAIR 40043 Portable Compressor $195.00
The Viair 400P is a larger portable compressor kit that can inflate up to a 35-inch tire from zero to 30 PSI in less than five minutes. Used and approved of by off road enthusiasts worldwide, the 400P can save you when you're miles from home.
VIAIR 44043 Portable Compressor $289.00
The Viair 440P is the ultimate portable compressor kit. It can inflate up to a 37-inch tire from zero to 30 PSI in less than 5 minutes. The 440P is the largest and most powerful portable compressor kit available today. Rock crawlers and semi-truckers alike will find the power of this unit irreplaceable.
VIAIR 10007 On board Air Compressor $389.00
By ordering a single part number, you can take all of the guess-work out of getting all of the parts you'll need to install one of the most sophisticated, all-inclusive on-board air systems available today. The Viair Constant Duty On board Air System comes complete with a long-running 450C, 100% Duty Cycle compressor at its heart that will fill the supplied 2.5 gallon tank from 110-150 PSI in approximately one minute. Unlike our other systems, the Constant Duty On board Air System can operate for longer periods of time without needing to rest. Viair included everything you'll need to add a reliable air source to your vehicle as well as inflate tires with the included clip-on air chuck.(For vehicles with up to 37-inch tires)
PM, E-mail, or Call for more information or to place an order.
John
Old Dec 7, 2011 | 06:25 PM
Nick-NY's Avatar
Nice prices. very tempting.
Old Dec 8, 2011 | 06:33 AM
arkain04's Avatar
Veteran: Navy
How long can we expect this sale run through...??
