ICON Vehicle Dynamics 3" Lift Kit for Jeep JK
Old 06-06-2012, 08:41 AM
Former Vendor
AJUSA.com's Avatar
Default ICON Vehicle Dynamics 3" Lift Kit for Jeep JK
is please to announce another new release from IVD for the Jeep JK
ICON Jeep Wrangler JK 3
The ICON Vehicle Dynamics 3" Lift Suspension System is designed for Jeep JK owner's demanding the ultimate in performance and ride quality, without the larger stance you find in bigger lift systems on today's market. Our ICON Jeep Wrangler Jk 3" lift system is engineered with front and rear dual rate progressive wound springs which is the foundation for on and off road performance and suspension articulation. The dual rate design gives you a softer initial rate for superb on road comfort and a firmer than stock secondary rate that increases during compression for excellent bottom out control. ICON V.S. 2.0 Aluminum Series shocks add the finishing touch with vehicle specific valving, OE mounting, and aircraft grade components. Together these components add 40% more wheel travel over stock helping you rock crawl safer or soak up larger terrain at higher speeds, keeping those wheels on the ground. This ICON 3" JK lift system is designed from the ground up to give the 07+ Jeep Wrangler JK's the best performance, suspension handling / ride quality, and clearance for 33" tall tires (35" tall with installation of aftermarket fenders).
Stages 2 & 3 feature upgrades components like V.S. 2.0 Aluminum Series Remote Reservoir shock for added shock cooling to prevent shock fade when you really plan to off road our JK, and adjustable pan rod bars for optimum axles positioning.
Key Features:
• Dual Rate Coil Springs Front and Rear
• Adds 40% More Wheel Travel over Stock
• No Welding or Cutting
• Vehicle can be Returned Back to Stock
• Includes High Performance Re-buildable / Re-valvable IFP 2.0 Aluminum Series Shocks
• Level Stance Front to Rear
• Out Articulates Most Long Arm Kits of Comparable Height
• 100% Made in the USA
• Lifetime Guarantee that Coil Springs Won’t Sag
Please email or pm us for pricing.
Chas Moore
forums@ajusa.com
800-877-1911
Old 06-06-2012, 10:59 AM
Merlin4979's Avatar
Interesting. Do you guys have anything to center the axle from side to side as well? (i.e. adjustable track bar) or control arms?
*edit - just saw the optional "pan-rod" bar
Old 06-06-2012, 11:39 AM
Former Vendor
AJUSA.com's Avatar
Yes sir! Standard in the stage 3 system.
Old 06-06-2012, 12:19 PM
33 williys 77's Avatar
Where's your bump stop's
Old 08-08-2012, 11:13 AM
Former Vendor
AJUSA.com's Avatar
IVD Jk Testing - Check out the Rigid light mount setup
Old 08-08-2012, 11:56 AM
onsafari's Avatar
I'm assuming at the bottom of the pictures on the outsides of the tracbars. This kits appears to not replace the rubber bumpstops.
Old 08-09-2012, 09:19 AM
Former Vendor
AJUSA.com's Avatar
Correct, those are bump stop spacers that lower the factory unit.
Heres a copy of the install instructions for those interested.
http://www.iconvehicledynamics.com/w...jeep3inch1.pdf
Quick Reply: ICON Vehicle Dynamics 3" Lift Kit for Jeep JK
